Sponsored by: Real Truck
coach21
Old Jul 7, 2020 | 10:20 PM
pasocoach's Avatar
pasocoach
coach21
I have a coolant leak coming from a factory plugged port that has two other ports with a hose to each only accessible from under the passenger side firewall area, does anyone know what this is and how to fix it?
Thanks All,
Old Jul 9, 2020 | 09:21 PM
pasocoach's Avatar
pasocoach
2008 250 6.4 super duty
Old Jul 9, 2020 | 09:23 PM
pasocoach's Avatar
pasocoach
I believe it is a heater core hose manifold? inlet outlet and a third below those two which is leaking but looks like a factory plug
Old Jul 9, 2020 | 09:25 PM
m-chan68's Avatar
m-chan68
Heater core??? A picture of the suspect source would help.
Old Jul 9, 2020 | 10:54 PM
pasocoach's Avatar
pasocoach
Sorry I am new, I guess I better get my ? together
truck 1 pic from passenger fender well removed and truck 2 pic from underneath looking up by firewall
thanks
File Type: html
File Type: html
Old Jul 11, 2020 | 09:58 PM
pasocoach's Avatar
pasocoach
I found out it is the evaporator core, it has inlet and outlet but also has a plastic port directly below the other two. it is leaking out of that, can that be plugged/ and what is the port for?
Thanks
Old Jul 12, 2020 | 10:40 AM
m-chan68's Avatar
m-chan68
That is supposed to be leaking......water that is. If there is anything other than water that is exiting that port you have a failure of either the evaporator core of it's freon dye, or the heater core of it's coolant.
Old Jul 12, 2020 | 02:50 PM
pasocoach's Avatar
pasocoach
Oh good I was hoping for that
Thanks for the response
James Wagoner
Feb 27, 2020 07:58 PM
bizzelj
Dec 13, 2015 09:09 PM
jwylie2125
Nov 26, 2012 04:53 PM
droffan
Nov 18, 2011 01:00 PM
first truck
Jul 29, 2009 09:02 AM
