OBD1 test plug location???
Old Jul 7, 2020 | 07:36 PM
union_guy's Avatar
union_guy
OK this one has me scratching my head can anyone find the OBD1 test plug in this photo? It's supposed to be under the hood hinge and it just is not there on my 1991 Ford F250 at least that I can see.
Old Jul 7, 2020 | 08:34 PM
Elita Harris's Avatar
Elita Harris
I cant tell by your pics but mine is attached to truck body above and toward the back of front drivers tire under the hood
Old Jul 7, 2020 | 08:45 PM
union_guy's Avatar
union_guy
Near the tire iron? Thanks for the tip.
Old Jul 8, 2020 | 06:23 AM
subford's Avatar
subford
Its on the drivers fender under where it says EEC test in the photo below.
Old Jul 8, 2020 | 06:35 AM
torq'ta 5 8's Avatar
torq'ta 5 8
no, sir should be father back, same area that the remote ICM that someone installed, the holder may have broke and its laying down
pic courtesy of subford
Old Jul 8, 2020 | 06:41 AM
rla2005's Avatar
rla2005
The remote mount ICM is most likely a factory item if the OP's truck has a 460/7.5L engine. I believe Subford has the correct EEC test port location since the truck is a 1991 model year.
Old Jul 8, 2020 | 06:53 AM
torq'ta 5 8
thanks, thats going in memory bank, havent seen them there.
Old Jul 8, 2020 | 07:14 AM
subford's Avatar
subford
He does have a 460 (7.5L) in his 1991 F250.
The remote ICM would be factory.
Old Jul 8, 2020 | 08:22 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Found it! Isn’t that gray connector the self test input wire?
Old Jul 8, 2020 | 06:52 PM
union_guy's Avatar
union_guy
I guess I thought that was a relay I wonder what it so well. When I get home tonight I will check that out thank you
Old Jul 10, 2020 | 05:09 PM
union_guy's Avatar
union_guy
I went a little deeper on Google this is not my truck but this is where they live. I was confused because I kept reading they were on the fire wall there on the inner Fender and when they are not being used they are in a handy little plug holder. All of the early google images I saw had them just sort of laying on the wiring harness.
Old Jul 10, 2020 | 08:40 PM
My4Fordtrucks
Um... isn’t that the same picture that was in post #5?
Old Jul 10, 2020 | 09:11 PM
subford's Avatar
subford
It is also of a 1993 or newer truck.
Old Jul 10, 2020 | 10:18 PM
union_guy's Avatar
union_guy
Not my post. I don't lurk here.
Old Jul 11, 2020 | 07:32 AM
My4Fordtrucks
I’m confused. You started the thread.
