anyone using Corroseal to convert rust?
Old Jul 4, 2020 | 04:00 PM
AllenV's Avatar
AllenV
Corroseal (Corroseal.com) appears to be a product that actually converts rust to a stable form. But the application process seems finicky and little info is available as to overcoating with a final paint, such as urethane. Has anybody used this? If so, how was it used and what were the results?
Old Jul 4, 2020 | 06:04 PM
Mixer man's Avatar
Mixer man
I've used it in the bilges and topsides on ships. Works great. Goes on white then turns black. Paint right over it with oil based paint after it cures. Never used a primer with it.
Old Jul 5, 2020 | 02:19 PM
CharlieLed's Avatar
CharlieLed
I have used it quite often in the nooks and crannies of the lower doors and in other pinch weld areas where dirt/water can settle and rust form. Good for coating the door channels around the window openings prior to installing the channel felts.
fepowerguy8
General Automotive Discussion
Apr 29, 2010 02:38 PM
John - NNY
Nov 30, 2007 11:32 PM
Encho
Paint & Bodywork
Jun 23, 2005 11:42 PM
