I have no Idea where to start to fix this. When I went to the parts store they said they did not have this sensor. I guess they looked for a Evap Sensor.
Truck is a 2010 5,4l with 205K, I just bought this truck, and this light was was on when I bought it. I'm new to Ford so any help will be greatly appreciated.
An open or shorted fuel tank pressure sensor circuit
A faulty canister vent valve (somewhat rare)
A faulty PCM (rare)
Common mistakes when diagnosing ...
The most common mistake associated with a P0451 code is failing to properly inspect all components, wiring, and connectors before replacing any part of the evaporative emission control system. For example, in some cases, a vacuum leak could be due to a loose or damaged fuel cap, not a faulty vacuum hose.
I am under the impression (from Fordtechmakuloco on youtube) that the most common cause of this and other evap codes is a bad evap purge valve (the one on or near the intake manifold). Unfortunately, not the case for me and I'm trying to figure out a goo way to DIY troubleshoot the rest of the system without shotgunning components.
