Gear ratio
Old Jul 2, 2020 | 09:02 PM
Bearwhiz's Avatar
Bearwhiz
Gear ratio
I just purchased a 2019 F250 4x4 with the 6.2 gasser. I have run my VIN thru two different sights but am unable to find out what my gear ratio is. Any help would be appreciated.
Old Jul 2, 2020 | 09:22 PM
ncl's Avatar
ncl
Check the door. Axle code will have a number. 4 is 4.30. 3 is 3.73 I believe.
Old Jul 3, 2020 | 10:22 AM
Ding126's Avatar
Ding126
should be info on the pumpkin
Old Jul 3, 2020 | 10:52 AM
Bearwhiz's Avatar
Bearwhiz
Sorry, but I'm new to Fords. Whats a pumpkin?
Old Jul 3, 2020 | 12:13 PM
6.2caribou's Avatar
6.2caribou
The pumpkin is just a slang word for the rear differential. There's no need to crawl under the truck. As NCL said, open the driver's door and look look at the sticker (white, not yellow). Axle code will be listed there.
Old Jul 3, 2020 | 12:14 PM
Kdawg89's Avatar
Kdawg89
If you look at the rear axle it is the bit in the middle that is pumpkin shaped.
Old Jul 3, 2020 | 12:41 PM
Bearwhiz's Avatar
Bearwhiz
Got it, Thanks.
Old Jul 3, 2020 | 12:54 PM
fmuguira's Avatar
fmuguira
If all else fails can jack up rear end and count drive shaft revolutions vs one rotation of the tire. Less than 4 equals 3.73... slightly more than 4 equals 4.30 !
Good Luck.
Also so you can drive truck at 60 mph in overdrive or 1 to 1 gear and look at Rpm s ... with a little math and tire size circumference can figure it out that way too.
Old Jul 3, 2020 | 01:04 PM
Reactor111's Avatar
Reactor111
If new it’s on the window sticker.
Drake12
Feb 14, 2020 02:41 PM
HILLBILLY BOB
Nov 17, 2011 09:19 PM
superduty00
Nov 7, 2010 10:29 PM
dieseldoc
Nov 22, 2006 08:36 AM
