Front Differential bolt torque
Old Jul 2, 2020 | 02:57 PM
JARED_LA's Avatar
JARED_LA
2020 F250. What torque setting?
Old Jul 2, 2020 | 04:41 PM
mwheue's Avatar
mwheue
are you looking for all torque specs? Cover, pinion, inner diff? I don't have a answer but being more specific will help you get one...
Old Jul 2, 2020 | 05:32 PM
JARED_LA's Avatar
JARED_LA
Cover. I installed Kelderman dual SS and found a small leak
Old Jul 2, 2020 | 05:55 PM
CT_Hiker's Avatar
CT_Hiker
Trailering
JARED_LA -- I had the same problem about a month ago. Called Kyle at Kelderman and he said that happens occasionally and that he didn't think it was that the bolts weren't torqued enough, but that a bolt hole may penetrate into the housing. Kyle suggested to remove the two new bolts, coat the threads with a bit of RTV, and retighten. I used a bit of Permatex Ultra Black on the threads and tightened to 35 ft/pounds (I think I've heard 33 - 38 ft/pounds on those cover bolts somewhere here on the forum). No doubt coating those threads messes up the torquing, but oh well. Let it set for 24 hours and no more leaks.
Two weeks ago put 100 miles in 4H and 10 in 4L on some nasty forest services roads and still no leaks.
Suggest giving Kyle a call. Those guys are super helpful and there is always a chance I misunderstood something (wouldn't be the first time).
Old Jul 2, 2020 | 08:36 PM
JARED_LA's Avatar
JARED_LA
Thanks, I sent an email to Kyle with pictures and received an automatic reply. I’ll try the Permatex Black.
Old Jul 3, 2020 | 02:09 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Torque spec is 45ft-lbs
Old Jul 3, 2020 | 04:21 PM
CT_Hiker's Avatar
CT_Hiker
Trailering
Whoops - guess I need to tighten those a bit more.
Many thanks. Your electronic repair manual has now helped me with the torque on front and rear shocks and on the front diff cover.
Old Jul 3, 2020 | 06:40 PM
JARED_LA's Avatar
JARED_LA
Thanks. Permatex appears to have done the trick.
kevincw
Dec 12, 2008 08:47 AM
wayneasbell
Aug 2, 2007 02:24 PM
tjbeggs
Apr 3, 2006 03:21 PM
Rat wagon
Apr 4, 2003 09:38 AM
old hippy
Garage & Workshop
Jan 28, 2003 08:44 PM
