06 5.4 help
Old Jul 1, 2020 | 10:13 PM
moneymike's Avatar
moneymike
06 5.4 help
Ok still working on my mom's truck, I have found when hot and you just blip the throttle or just give it steady slight throttle it starts running very rough. Fuel trim goes +40 bank 1 -20 bank 2. Rev it up a few times engine smooths out but kinda rough. Fuel trim bank 1 -8 bank 2 +3. Smoked intake found no leaks. Vacuum at intake at idle 18invac. 20 invac under load. Any thoughts. Gonna bring fuel guage home tommarow and check fuel pressure. Any ideas on what else to check
Old Sep 12, 2020 | 04:01 PM
Steve Hutchinson's Avatar
Steve Hutchinson
Did you figure it out?
Any update?
Old Sep 12, 2020 | 09:57 PM
moneymike's Avatar
moneymike
No not yet
Old Sep 12, 2020 | 10:12 PM
F150Torqued's Avatar
F150Torqued
@moneymike your symptoms are 'CLASSIC' timing symptoms resulting from Phasers that cannot HOLD cams at proper position on supplied Oil Pressure at the given RPM.. Translating them into specific mechanical (or rather hydraulic) causes is a little bit tedious. Generally speaking: The Phasers have a spring loaded locking pin internal that captures and locks the Phaser into base (zero retard) as the engine idles down from RPMs that produce enough oil pressure to assure Phaser can push cam to Zero Retard.
As long as engine idles and oil pressure is insufficient to UNLOCK the spring loaded locking pin - the phaser stays locked in full advance position --- even if Oil pressure is insufficient to do the job.
What you describe -- "give it slight acceleration", as RPM rises so does oil pressure. Once the Locking pin dis-engages (it is spring loaded), then the oil pressure MUST be sufficient to take over and hold Phaser at 'proper' position (whatever the PCM is requesting) - which is still ZERO degrees retard below about 800 to 1000 RPM "AND" below 25% engine load.
Your 'rough running' is classic symptom of the two banks cam timing NOT being balanced. A retarded cam does NOT aspirate as much air - so the cylinders on that bank are "WEAK". That condition is 'CONFIRMED' by your inbalanced Fuel Trims. Less air being drawn in makes fuel mixture WRONG for that bank and the PCM sees it at the O2 sensor and attempts to compensate. The oposite bank works harder trying to help the lazy side and drives its fuel trims the opposite direction. The CAMS are not synchronized equally with the crankshaft.
WHY. Probably a tensioner blown degrading oil pressure in one head - or possibly more serious oil pressure loss in one head or Phaser vanes.
Sorry for the bad news.
Old Sep 12, 2020 | 10:20 PM
Steve Hutchinson
VCT Solenoid
Great explanation. 👍 A bad or clogged VCT solenoid would also create that scenario too, wouldn't it... As for the pin, I thought it was a locating pin, but it actuates?
Old Sep 13, 2020 | 01:25 AM
F150Torqued
You're right. That's what is hard about diagnosing our phaser system. About anything in the system can cause similar symptoms. It would be possible for the screen on a VCT solenoid to break or clog or something to limit oil flow/pressure from getting to the Phaser effectively.
Yes, the little locking piin (about the size of a pencil) about 1/2 inch long has a spring under it. The spring pushes it up and locks the two halves of the Phaser together. Oil pressure ---- Above a certain pressure ????? --- pushes it down and allows the vanes in the actuator chambers to move the back half (connected to the CAM) with respect to the front half (connected to the gear).
Both banks are controlled INDEPENDENTLY by the PCM in a 'positive feedback', closed loop fashion. Controlling position with VCT solenoid and reading actual position by CPS sensors. (Actually amazing it works as well as it does).
brade
Mar 25, 2015 05:26 PM
Blackbusa
1997 - 2003 F150
Jul 28, 2014 07:24 AM
carey965
2004 - 2008 F150
18
May 13, 2013 08:51 PM
hedhntr
16
May 6, 2010 09:44 PM
vaughnr007
2004 - 2008 F150
Nov 6, 2008 01:49 AM
