Id'ing Front & Rear Differential's
Old Oct 19, 2003 | 12:13 AM
fordman400's Avatar
fordman400
Can someone tell what kind of rearend and front axle are on my 78 f150
I am trying to see what the gear ratio of my front and rear axles are and wht type I have on my Truck. The only thing I have for you is that the axle code on my door says H2 J if that helps any.
Old Oct 19, 2003 | 12:41 AM
LxMan1's Avatar
LxMan1
3.50's are pretty common. I don't have a chart in front of me to verify though.
Jimmy
Old Oct 19, 2003 | 12:45 AM
Matts72's Avatar
Matts72
You have a Famous Ford 9" rear end, and its probably limited slip, with a 4.10 gearing, and the front is a Dana 44 open 4.09 gearing.
there are casting codes on the Dana housing, and a tag on the 9". you can post those here and soemone will be able to decode them for you.
Most VIN codes aren't reliable, since a lot of these trucks get mixed and matched over the years.
*edit
Your data plate says it is a 3.50 geared limited slip 3750lb axle. Only the tags will tell the truth.
Old Oct 19, 2003 | 10:15 AM
plowpusher's Avatar
plowpusher
H2=3.50 gears according to the chart
Old Oct 19, 2003 | 01:57 PM
fordman400's Avatar
fordman400
thank you guys I will look for the tags on the housing.
Old Oct 19, 2003 | 02:16 PM
Txquadhunter24's Avatar
Txquadhunter24
h2 axle code is 3:50 LS
Old Oct 19, 2003 | 04:56 PM
fordman400's Avatar
fordman400
Thanks again but does anyone know the J is for the front axle. The tags are not on the axle anywhere.
Old Oct 19, 2003 | 05:59 PM
Matts72's Avatar
Matts72
The front is geared the same as the rear.
Old Oct 19, 2003 | 07:35 PM
Mil1ion's Avatar
Mil1ion
J means the truck has power steering.
Maybe have a look at MY website and see all of the info.
Old Oct 19, 2003 | 07:42 PM
fordman400's Avatar
fordman400
okay thankyou for that bit of info
Old Oct 19, 2003 | 10:54 PM
badass truck's Avatar
badass truck
hey fellas just read this , its about rear ends. so i figuered you might know this, ts pretty dumb question but i'm a beginer. my rear end says 60 and some letters and my front end says 44 then some letters on the lower right hand side of the differental of each. does this mean my truck has a dana 60 in the rear and a 44 in the front?? and its a 79 f250 4x4
thanks
Old Oct 19, 2003 | 11:19 PM
grapegravy's Avatar
grapegravy
Yes,,,,,
Actually, dude, your axles are backwards, the 60 is supposed to be in the front and the 44 in the back. Looks like you have some serious work on your hands,,, j/k
Old Oct 20, 2003 | 12:29 PM
gdavis2265's Avatar
gdavis2265
Turn the seat around and drive backwards
Old Oct 20, 2003 | 01:15 PM
badass truck
thanks for the lil bit of comedy fellas. i was pretty sure about the 60 meaning dana 60 but just checking. thats to bad i only have a 44 in the front. is it easy to swap a 60 in there?
Old Oct 20, 2003 | 01:21 PM
gdavis2265's Avatar
gdavis2265
DANA 60 front's are over 1K around this area. You might be able to find a HD Dana 44- uses 60 hubs, knuckels and shafts and a 44 ring and pinion.
