Today i went to start my truck and it kit up all the icons on the dash and sang me a song with chimes. I turned off my key and restarted and then it was fine. .
Get home today run a DTC with OBDlink LX and my Ezlynk software. Holy moly the codes it threw...
Has anyone ever come across this ? .truck is a 2019 f150 powerstroke 17k on it.
i was able to get most to clear but im sure theyll be back..
Even though you cleared some or maybe even all the codes by now, those codes are still in the system and your local Ford dealer will be able to read them.
With that being said and since your vehicle is still under the factory warranty, take it into your Ford dealer of choice and let them figure it out and fix it.
Have you added some type of aftermarket engine tune or something?
Yes, it is tuned and deleted along with an S&B intake.
only happened once but other than that runs great.
