Help
Old Jun 29, 2020 | 11:38 PM
Wcmtz's Avatar
Wcmtz
Help
I have a 96 7.3 I just put new injectors new IPr new icp and the truck runs great and strong I’m having one issue that is when I Q up my vhf tow way radio it kills the engine as if I shut the key off or it will miss and sputer Until I release the mike I’m stumped with this
Old Jun 30, 2020 | 05:21 AM
97-psd's Avatar
97-psd
Is it a portable or truck mounted radio?
Old Jun 30, 2020 | 08:09 AM
z31freakify's Avatar
z31freakify
I've read here on the forums that some members reporting their trucks dying when going thru radio/power towers. IIIC it had something to do with the CPS signal being interrupted by the radio/magnectic waves. Don't remember what the fix is but should give you a perspective of whats going on.
Old Jun 30, 2020 | 08:22 AM
Wcmtz's Avatar
Wcmtz
both will do it
Old Jun 30, 2020 | 08:24 AM
Wcmtz's Avatar
Wcmtz
I’ll try replacing it this evening thanks
Old Jun 30, 2020 | 09:26 AM
BuddyBarnes's Avatar
BuddyBarnes
Like z31 I have not heard of this problem for years but at one time there were some problems and I also think the cure was the CPS. (IIRC) That being said get new motor craft one. About $28 even from dealer.
Old Jun 30, 2020 | 01:28 PM
Wcmtz's Avatar
Wcmtz
thank you I’ll try that
Old Jun 30, 2020 | 01:40 PM
JayTheCPA's Avatar
JayTheCPA
I had also seen where corroded grounds did this. Might want to take a look at the block-to-frame ground.
Old Jul 1, 2020 | 07:59 PM
Wcmtz's Avatar
Wcmtz
so it’s not cps or a bad ground I’m leaning toward the pcm/ecm or IDM any ideas or advice thanks in advance
Old Jul 5, 2020 | 06:08 PM
helifixer's Avatar
helifixer
icp can be affected radio interference, exhaust back pressure sensor can be affected by radio interference.
both can be tested by unplugging them and see if the problem still exists or goes away.
Jeff Brillon
Nov 4, 2019 04:46 AM
szotty
Ford Truck Parts for Sale
Nov 4, 2015 02:15 PM
SuperDoodie
Nov 24, 2009 08:44 AM
ogzilla
Jan 18, 2004 10:16 AM
