Looking for power brake advice
I'm currently working on the brakes. The rear drum brakes (on a newer 9" rearend) are done. I'm installing a new disc brake kit up front. This past weekend I was running new brake lines on the rearend and thought I was just going inspect the rest of the lines. It turns out the brake booster and master cylinder were installed in a pretty hokey way. It looks like a nice, new bracket was installed, but I can't tell the vintage of the brake booster and master cylinder. The way it's all mounted forces the master cylinder upward right into the floor of the cab. I also think there are issues with how it's all plumbed up. Overall I'm bummed with how the PO did this, so I've taken the setup out and am trying to figure out how to move forward.
Can anyone share their experience with either a below-floor power brake setup using the stock brake pedal, or a firewall-mounted setup? I'm considering both options. I like the idea of using my stock pedal, and I'm not opposed to cutting an access hole in the floor for the master cylinder, but I'm curious who's had good/bad experiences with different ways of doing it.
At least from the pictures, it looks like somebody did a decent job installing it. At least you have OEM U.S. made parts. The boosters in the kits available today are imported and not rebuildable because they use metric sized internal components.
There are plenty of folks running under the cab Masters, Original, Manual and Power. You didn’t say how the brakes are working. There are a few issues I see; don't see a brake light switch, no check valves in the lines and it looks like there are two brake lines running towards the rear??? As you will quickly learn there are a zillion ways people do things. My point being if it’s working leave well enough alone. There will be plenty of things that need fixing as life goes by.
The previous owner installed a nice, rugged bracket meant for this job, but the odd thing about it, which is hard to see in photos, is how the assembly runs at an uphill angle (relative to the frame rails) and drives the master cylinder right into the floor. I'm okay with cutting a new access hole, but I'm not sure if I want to keep this setup. Decisions, decisions...
bjmayberry2, the truck hasn't been driven since the brakes were put on it 20 years ago. I'm not sure how they would do, but with two lines going to the back I'm sure I wouldn't like it!
Thanks guys
jerry
https://www.summitracing.com/parts/c...CABEgLrqfD_BwE
