Sponsored by: Real Truck
Brake problems!!!!
Old Jun 27, 2020 | 08:36 PM
Chris Haley's Avatar
Chris Haley
Brake problems!!!!
I have an 02 F 250 I have replaced the abs module,brake booster,new calipers and rotors on the front along with a new master cylinder and still only have brakes when I stomp on the pedal. No pedal when just pressing normal. Brakes have been bleed.
Please Help
Old Jun 27, 2020 | 08:54 PM
xd2200's Avatar
xd2200
Check to make sure calipers are not upside down (i.e., L on R & R on L) Bleeders need to be on top. "My friend" made this mistake.
Old Jun 27, 2020 | 08:58 PM
Chris Haley
Everything is the right way... but thank you
Old Jun 28, 2020 | 08:58 AM
bwguardian's Avatar
bwguardian
I would be looking at the rubber lines from the hard lines to the calipers as they deteriorate from the inside out and will swell up not allowing brake fluid to move through. There's probably another one at the rear axle that goes from the hard line on the body to the hard line on the axle.
Old Jun 28, 2020 | 08:45 PM
TooManyToys.'s Avatar
TooManyToys.
Please Help
Where did you get the master from? For most applications, I only recommend the dealer.
No pedal on slow application but firm on fast application is the classic sign of a master bypassing.
reddyj
2004 - 2008 F150
15
Apr 13, 2020 01:04 PM
Razkid
2009 - 2014 F150
Aug 26, 2019 02:20 PM
largefries
Sep 29, 2010 12:37 AM
Thomas A
Oct 25, 2005 03:42 PM
max82
Sep 30, 2003 03:20 PM
