Hei distributor
Old Jun 26, 2020 | 04:29 AM
Jimmy nz's Avatar
Jimmy nz
Hei distributor
Hei distributor in my 66 should I run a new wire from the ignition switch to the dizzy or is the original resister wire ok to use
Old Jun 26, 2020 | 10:24 AM
rdixiemiller's Avatar
rdixiemiller
I think they require a full 12 volts.
I know my Pertronix distributor conversion requires full voltage.
Old Jun 26, 2020 | 11:07 AM
ford390gashog's Avatar
ford390gashog
HEI requires full voltage or you will burn up the module.
Old Jun 27, 2020 | 07:33 PM
manglass's Avatar
manglass
You might try using the resistor wire to trip a relay from the battery.
Lou Manglass
Old Jun 27, 2020 | 09:29 PM
SwampRattFord's Avatar
SwampRattFord
Pertronix sells a relay to switch with the resistor wire and feed the full 12 v to the dizzy. If you decide to go that route I have one of their relays I never used I would sell. PM me if interested. Hope that’s ok to say here.
Old Jun 27, 2020 | 10:22 PM
Christmas's Avatar
Christmas
It's real easy to eliminate the "Pink" wire and splice in a solid wire under the dash.
Old Jun 28, 2020 | 01:31 AM
Jimmy nz's Avatar
Jimmy nz
Thanks for all your help I've run a new wire seems to work ok
Old Jun 28, 2020 | 08:26 AM
harley7991's Avatar
harley7991
A tangent - I have the hei distributor and Taylor 64666 wire set on my 300.
Supposedly others use this combination, but routing the wires is a bit challenging, and they seem almost too short. Anyone else have experience with this?
Old Jun 29, 2020 | 12:57 AM
tbm3fan's Avatar
tbm3fan
This^^^^. In fact on my 65 there was actually a bullet connector right at the ignition switch. Unplugged the pink wire and plugged in another wire to run 12V over to the Pertronix. Otherwise you can use a relay like I use in my Park Lane, Cougar, Mustang, and Polara that has an HEI that I made up.
Old Jun 29, 2020 | 01:59 AM
Christmas's Avatar
Christmas
I always buy a universal set and make my own. Makes routing them much easier.
Smokdu1973
42
Jun 16, 2020 09:32 AM
CRUNKED77FORD
Aug 25, 2011 02:18 PM
1972-34ton
Apr 24, 2009 08:35 PM
302 F-150
Electrical Systems/Wiring
Jun 16, 2007 09:23 AM
