300 valve lash adjustment?
Old Jun 27, 2020 | 10:14 PM
harley7991's Avatar
harley7991
I'm chasing an oil leak and have the valve cover off on my 300. I figured I should probably set the valve lash, but then I realized it uses hydraulic lifters. I'm used to shimming overhead cams. So, how do you set the valve lash on the 300?
Also, should I make sure the push rods are flowing oil? How messy is it to run the engine with the valve cover off?
Old Jun 28, 2020 | 11:31 AM
harley7991's Avatar
harley7991
Well, turns out some of the pushrods are bent. So adjusting the valve lash doesn't make sense to me until I fix that. I figure I should replace the lifters as well. That might explain why the engine doesn't run super smooth.
Anyone try Comp Cams 7866-12 and 832-12 for pushrods and lifters? Should I use something else?
Old Jun 28, 2020 | 11:36 AM
k2evd's Avatar
k2evd
try posting in the "inline six forum" lots of good info and helpful folks there
Old Jun 28, 2020 | 06:59 PM
third66go's Avatar
third66go
Harley, check your PM
Old Jun 29, 2020 | 11:14 AM
jjriley97's Avatar
jjriley97
Setting the valve lash with the cover off is the way to go. It's not very messy at all. This was the way I had to do mine. I tried the ways that I found online, but found the live running motor to be the easiest and most effective for me.
JayzDaddy
May 29, 2014 05:00 PM
FlaresideF150
Apr 1, 2011 02:56 PM
82f-100
Apr 27, 2009 10:11 PM
gingerbreadmaniac
May 13, 2003 07:14 AM
