Automatic column shifter problem
Old Jun 25, 2020 | 08:58 PM
Nitro1168's Avatar
Nitro1168
I just bought a 79 150. I’m working on all the mechanical issues and one of the problems is the gear shifter is to smooth it’s not nauchy like it should be. I half to move the shifter around to find the right gear. Can it be fixed or should I just get another one?
Old Jun 26, 2020 | 12:11 AM
caravaggio2000's Avatar
caravaggio2000
Check the the linkage where it hooks up to thw transmission shifter for slop and adjust the hardware there. Set it up so everything lines up with the correct gear on the indicator and then snug it all down. Be careful not to let the truck roll over you while you are down there. It's not hard to pop it into neutral accidently.
Old Jun 26, 2020 | 09:04 AM
Nitro1168's Avatar
Nitro1168
Ok thanks, I’ll take a look at it. I didn’t know there was a adjustment there
Old Jun 26, 2020 | 09:32 AM
beartracks's Avatar
beartracks
It's likely the "sector" under the steering wheel. A pice of metal with notches in it for the gears.
Old Jun 26, 2020 | 10:53 AM
Nitro1168's Avatar
Nitro1168
Thanks, I’ll check that also
Old Jun 26, 2020 | 10:54 AM
Nitro1168's Avatar
Nitro1168
breno1987
Aug 10, 2011 05:08 AM
IZZYAZ
Aug 18, 2009 08:29 AM
rmalottwtes30
Mar 19, 2008 08:10 PM
