Changed the oil tonight
Old Oct 18, 2003 | 08:19 PM
trakman's Avatar
trakman
Smile Changed the oil tonight
This is the first time that I have changed the oil in my PSD since becomming it's new owner and I didn't think the oil was ever going to quit running out of the pan Though I'd struck an oil well! 15 quarts seems like alot when you've been use to the old 351 gas engine that held 6 quarts..leaked 2 of them out on the garage floor...burnt 1 in 2000 miles and really only had 3 to drop out in the catch pan LOL
Anyway, upon changing the filter, I find I don't have a wrench to fit that big oil filter...had to use a giant set of channel locks to get it off. Is there a wrench made to fit that size of filter and where do I get one? Thanks
Old Oct 18, 2003 | 09:07 PM
TheUglyTroll's Avatar
TheUglyTroll
You can find one at any auto parts place...
However, I like and use a Craftsman strap wrench that I got at Sears - I got a set (large and small) on sale for about 20 bucks US. Works great for me.
Drive Safe!
TUT
Old Oct 18, 2003 | 09:12 PM
state's Avatar
state
I ran into the same thing. Advance Auto Parts has a 4 inch filter wrench. Works great. It's not the one with a chain. Cost about $8.
Old Oct 18, 2003 | 11:22 PM
HeatStroked's Avatar
HeatStroked
Use the same flex wrench to change your fuel filter too.
Old Oct 19, 2003 | 05:14 PM
DPMPSD's Avatar
DPMPSD
I use a strap wrench and do yourself a favor punch a hole in the bottom of the filter before removal saves a lot of mess
Old Oct 19, 2003 | 05:44 PM
state's Avatar
state
Great idea. I wish this topic had come up about a week earlier. Would have prevented the 2 quart oil slick in my driveway caused by me dropping the filter.
Old Oct 19, 2003 | 06:07 PM
vans's Avatar
vans
first time I changed oil I found out about needing larger wrench, went to local Napa. K&N oil filters have a nut incorporated to bottom of filter, you could use either a socket or wrench, wish all filters had this feature.
Old Oct 19, 2003 | 08:29 PM
Jlower's Avatar
Jlower
A friend of mine pointed me to a Fumoto valve for the oil pan. It screws in place of the drain plug. It even has a hose barb so you can attach a hose to direct the drain. Takes me all of 2 minutes to drain the oil with no mess. And no tools needed. I too use the Sears strap wrench to pull the oil and fuel filter.
Cool idea on puncturing the filter to drain it out!
Fumoto Oil Drain Valve
Old Oct 19, 2003 | 11:28 PM
Diesel Steve's Avatar
Diesel Steve
Another good idea
I have the Fumoto valve and I like it very much. My good idea/advice is to make sure you prefill the oil filter next time, if you did not do so on your last oil change. You'll have to very carefully screw it onto the engine in order not to spill any new oil out (fill it reasonably full). I would sure hate to let my engine run dry while two quarts of oil is pumped into the filter before the lubrication begins!
Steve
Old Oct 20, 2003 | 05:14 AM
13hondacr250's Avatar
13hondacr250
First time I did mine I didn't do my homework. I have a filter wrench for the gasser but I drained out the oil and then realized the wrench was to small. Thankfully the filter is easily accesible with a screw driver. But does that ever make a mess. Hmm, dust control.
Old Oct 20, 2003 | 11:02 AM
trakman's Avatar
trakman
Oil Change
GREAT IDEA about punching a hole in the bottom of the filter! I too had a hell of a mess when I got it unscrewed....was thinking at the time that I wished the engineer that put the oil filter on the Triton V-10 would have give the motor engineer for the PSD the idea about hanging it straight down and in an area that allows for easy removal.
Old Oct 20, 2003 | 11:30 PM
eckart's Avatar
eckart
I normaly prefill the filter on the bench and then put a plastic lid or peace of cardboard over it so none of the crunchies from under the truck find their way into the filter before it gets installed. A couple grains of sand could do a world of hurt in the oil.
