Need help wiring an aftermarket radio
Old 06-24-2020, 07:01 PM
7.3_4Life's Avatar
7.3_4Life
7.3_4Life is offline
Im having trouble trying to install an aftermarket radio in my 1988 F350, the previous one worked fine, The wires were atrocious and somehow it worked (I'll post a picture) anyway by going by a few diagrams online and thinking I got everything hooked up right, I turned the key. and nothing happened, just a blank Screen. I checked the fuse, Its not blown, Its got 12v. Oddly enough my ground wire is a green wire screwed directly a piece of metal above my ash tray (or whatever that thing is next to the cigar lighter.) Not sure if there's anything else to note.
The Previous radio was a "Pioneer mvh-s21bt"
https://imgur.com/gallery/iQ2vSRu <--- Pictures Provided
https://www.amazon.com/gp/product/B004S55GWK/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B004S55GWK/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
<--- New Radio
Old 06-27-2020, 10:12 AM
madsonp's Avatar
madsonp
madsonp is offline
I don't know if this will help or not, but it's the wiring colors for your year of truck. https://www.the12volt.com/installbay...etail/868.html
Old 06-30-2020, 05:29 PM
jjriley97's Avatar
jjriley97
jjriley97 is offline
Do you have a multimeter? The first thing I would check is to ensure the ground wire is actually ground. The metal plate in the dash may or may not be grounded to the frame, which is the ideal ground point. The next thing I would check is both accessory and permanent 12 volts. You have to have 12v on both to get the radio on. You don't want to run them off of the same 12v though. You need to have accessory powered off of the key to ensure the radio shuts off. If you bought the radio used, you can check the radio using the battery just to make sure it works.
The color code at the link above doesn't match this one, so you might see which one lines up with your truck. I use this site for most of my installs and they are right most of the time, but not always.
https://www.modifiedlife.com/1988-fo...e-color-codes/
You mentioned the fuse is good, but is it the one in the fuse panel or on the radio? Most radios have one on them.
Old 07-01-2020, 11:39 PM
7.3_4Life's Avatar
7.3_4Life
I'm a couple days late to responding, but I took the truck to the shop up the street this morning. He'll look at it. But, I checked everywhere with a multimeter, It was either not showing power, or showing 0.05v and I tested both radios. No luck.
Old 07-02-2020, 07:34 AM
jjriley97's Avatar
jjriley97
Either the ground is not a good one (my gut says this first) or the power wires need to be traced back and find where they are broken. Sometimes the shop is the easier choice. Let me know what they find out.
ckleine
10-02-2014 06:44 AM
GruesomeJeans
Electrical Systems/Wiring
02-15-2012 10:41 PM
for46016
1978 - 1996 Big Bronco
02-13-2009 11:00 PM
7sixf150
02-15-2007 05:07 PM
hyperpunkguy[F150]
05-13-2004 05:33 PM
Quick Reply: Need help wiring an aftermarket radio
