Project 7.3
Old Jun 23, 2020 | 09:18 PM
2011 f 350's Avatar
2011 f 350
Project 7.3
Hey guys,
just working on a new to me 2002 f 350 7.3 SRW I am doing rotors and callipers all around and when I took off the rear left wheel I saw that my axle seal is leaking. Just wondering if there's anything I should replace while I'm doing this job. bearings or other seals? Also, how do I identify my rear axle so I can order the right parts? They gave me like four options at the parts store.
Thanks!
Old Jun 24, 2020 | 06:26 AM
FordTruckNoob's Avatar
FordTruckNoob
Welcome to FTE (the 1999-2003 7.3 which is the bestest subforum in particular)! It's an SRW so it should be a Ford Sterling 10.5" axle. Take a pic of the tag on the pumpkin and we'll help you decode it.
Old Jun 29, 2020 | 10:33 AM
2011 f 350's Avatar
2011 f 350
Sorry for the slow reply... Heres a picture:
Im guessing its a 3.73 gear ratio and a 10.5 axle like you said??
Old Jun 29, 2020 | 12:05 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
thats a 10.5 " sterling, 3.73 with limited slip
Go with the oem style wheel seals, the one piece junk some of the parts stores try and sell you will start leaking in short order.
Also check your axle tube vent for blockage, as the axle heats up it needs to be able to breathe, with the vent blocked it can cause leaks like this.
Old Jun 30, 2020 | 09:55 AM
2011 f 350's Avatar
2011 f 350
Thanks. Do you think i should just do the seals or is there something else i should replace while im in threre
Old Jun 30, 2020 | 11:02 AM
KubotaOrange76
if beaarings and races look good no need to replace, id plan on ebrake shoes, yours are probably covered in oil now and trashed, might not be bad time to change diff oil since youll have to top off anyway.
Reactor111
Oct 23, 2019 12:37 AM
rbsample
May 23, 2011 02:22 PM
Franko72
Apr 27, 2010 06:44 AM
fordnut1985
Jan 12, 2005 04:29 PM
