Fuel Gauge
Old Jan 20, 2001 | 10:08 AM
treefort's Avatar
treefort
Fuel Gauge
I have a 1990 F-250HD with dual tanks and the tank switch works perfect and the fuel pumps were replaced a year ago, but the guagees don't work at all I used to wait till it sputtered then switch but that is why I replaced the fuel pumps what could be my problem on the guages???the guage reads about half or a qurter of a tank and never moves.
thanks
Old Jan 20, 2001 | 11:07 AM
bgodkin's Avatar
bgodkin
Fuel Gauge
Sounds like a bad ground on the tank to me. How did you make out with your F150? Still thinking about the dually ocnversion?
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Jan 20, 2001 | 10:49 PM
treefort's Avatar
treefort
Fuel Gauge
>the tank to me. How
>Brad Godkin
>1986 F350 CC/SRW
>6.9liter/C6
Well I am selling the f-150 and buying this f250HD just because it is an overall tougher truck the f150 just wasn't up to the task of towing the horses and cattle I was afraid the frame would break into pieces.
But,
this f250HD is single wheel and it has the 10.25 full floater what is involed in making it dually besides the fenders do I just buy 2 more wheels and mount them or what>???
thanks
Old Jan 21, 2001 | 01:16 AM
bgodkin's Avatar
bgodkin
Fuel Gauge
[font size="1" color="#FF0000"]LAST EDITED ON 21-Jan-01 AT 02:17 AM (EST)[/font][p]This will be alot easier. as for the rear wheels, I would pull off a wheel and look at the brake drum. on mine I have two blind drilled holes about 1/4" in diameter. these are for the alignment dowels for the dual rear wheels. You will probably have to buy the dowels through Ford or grab them at the junkyard when you get your rims.Are your lug bolts extremely long? if so then you shouldn't have to change then out, just the lug nuts. The single rear wheel version (SRW) uses a cone shaped lug nut like a normal lug while the Dual Rear Wheel version (DRW) uses a flat based lug nut with a spinning washer. This should have you doing the DRW thing quickly. You will still have to cut the box sides to clear the wheels however. One thing that might be cheaper than buying the fenders and cutting the box sides is to just buy a Box off of a Dually and sell yours. This would give you the factory fenders and be alot less PITA then cutting and pasting fenders. Just a thought though. You might even get lucky and find one that is the right color. Hope this helps. If I can be of anymore help give me a holler.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Jan 21, 2001 | 12:03 PM
treefort's Avatar
treefort
Fuel Gauge
>is to just buy a
>Box off of a Dually
>If I can be of
>holler.
>Brad Godkin
>1986 F350 CC/SRW
>6.9liter/C6
Do I have to buy new studs and have them pressed in or are these long enough??
also How do you put in the alighnment dowels they are just to hold the wheel right??
thanks
Old Jan 21, 2001 | 12:05 PM
treefort's Avatar
treefort
Fuel Gauge
sorry about the lug bolts you already answered that but do you know a measurement that I could see if they are long enough??
thanks
Old Jan 21, 2001 | 12:53 PM
bgodkin's Avatar
bgodkin
Fuel Gauge
[font size="1" color="#FF0000"]LAST EDITED ON 21-Jan-01 AT 01:55 PM (EST)[/font][p]nothing precise really. nie are about 1-1 1/4 " long when measured from the hub if yours are not long enough they are not a big deal to change really. The alignment dowels just press in. One presses into the brake drum and one is built into the outer wheel.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Jan 21, 2001 | 03:36 PM
fatforty's Avatar
fatforty
Fuel Gauge
