292 engine
Old Jun 20, 2020 | 11:23 AM
thrifty's Avatar
thrifty
292 engine
Is the 292 made in 2 versions? What I am asking is did they make a different version for big trucks opposed to a F-100, F-250? One with a longer stroke? Maybe this was done with trans and differential? I have an opportunity to buy one out of a larger truck.
Old Jun 20, 2020 | 12:25 PM
85e150's Avatar
85e150
Bore and stroke are the same, otherwise it wouldn't be a 292.
Yes, they made several varieties, and the engine changed from year to year as well. Compression was dropped over the years for one.
There was a heavy duty version with sodium cooled valves for medium trucks. Those also had governed carbs and I think a governed distributor.
There were 2bbl and 4bbl versions also.
In mediums, some, but I not sure about all, used a larger input for the transmission. An NP435 from an F600 vs and F100 for example. Not sure on the T98 used in the late '50s to mid '60s.
Differentials are vastly different, much heavier and larger. Many mediums had a two speed axle, the band aid for the limits of the 4 speed main transmissions.
You may have to use a different bell housing in a pickup or car, not sure. But if you are replacing a 292, then you can swap over whatever is different and make it work.
Old Jun 20, 2020 | 03:16 PM
thrifty's Avatar
thrifty
I got a little more info on the truck. It is a F700, it has a clark 5 speed in it. Distributor is not tach driven, has a 2 barrel. Just interested in the engine for another project. The cab belongs to me just has not been delivered.
Old Jun 20, 2020 | 04:49 PM
85e150's Avatar
85e150
Looks like a 292. I'm not sure the Lincoln Y-blocks used the crossover exhaust. The other obvious external difference is the intake manifold. Ford Y-block is stacked ports, Lincoln is side by side. As has been said about identifying an FE engine, Helen Keller could tell a Lincoln Y from a Ford.....
Old Jun 22, 2020 | 04:14 PM
charliemccraney's Avatar
charliemccraney
The valve cover and thermostat housing identify it as a Ford Y Block.
You can use the block number to at least narrow down what it may be. TECHNICAL
Old Jun 22, 2020 | 10:53 PM
thrifty's Avatar
thrifty
Thanks that's some good info!!!
1964FORDTUF
Oct 11, 2014 08:37 PM
cuellar23
Jun 1, 2013 10:28 AM
nicholls77
Mar 20, 2011 08:42 PM
bbslamjam
Jan 23, 2007 08:49 PM
