No Start
Old Jun 19, 2020 | 07:23 PM
#1Victoryrider's Avatar
#1Victoryrider
No Start
I have an 88 F 150 short box 4 wheel drive. I've had it since 2000 and it has always started and ran when nothing else would. It now has 270,000 miles on it and has several leaks, but I still love it. I came in and parked it 3 or 4 months ago and it hasn't hit a lock since. I've replaced the frame rail fuel pump, computer, fuel pump relay and still nothing. I'm testing for spark this evening. I miss my truck, any ideas??
Old Jun 20, 2020 | 01:58 AM
Vincent Eckert's Avatar
Vincent Eckert
Do lights go on in the truck when you turn the key? Do you hear the new fuel pump pumping? does it click when you try to start it?
My first idea beyond that would be to try to jump across the starter solenoid.
Old Jun 20, 2020 | 07:44 AM
My4Fordtrucks's Avatar
My4Fordtrucks
First thing to do is stop throwing parts at it. Not only does that make your wallet thinner and be frustrating but you might be replacing good parts with new parts of questionable quality.
When you turn the key to RUN” does the fuel pump run for a couple seconds to prime the system? Using a mechanical gauge check for pressure at the fuel rail. Are we to assume that the engine is turning over but won’t start otherwise there won’t be any way to test for spark since the engine isn’t turning. Have you checked for fault codes ( Key On Engine Off test ) to see if there are any active or stored codes? The check engine light does not need to be on for there to be codes.
Old Jun 20, 2020 | 07:47 AM
#1Victoryrider
I must have left out that it cranks over fine. It acts like there is no fuel or spark.
Old Jun 20, 2020 | 07:54 AM
#1Victoryrider
how do I check the codes on this one. It does crank over fine but that's all. Never tried to start.
Old Jun 20, 2020 | 08:05 AM
My4Fordtrucks
Here is a “How to” video. See post #2:
https://www.ford-trucks.com/forums/w....php?t=1622383
Old Jun 20, 2020 | 11:49 AM
Vincent Eckert
If The fuel pump is pumping, and the truck is turning over, it could just be that the fuel in your tank sat for too long between starting. you may just need to pour some fresh fuel into your air intake to get it to start that way, and once it's running it could knock out any bad fuel it's got stuck in the lines.
If pouring fuel directly into the air intake starts it then I would bet on bad gas gunking up your fuel lines.
If that doesn't start it then there's probably either an electrical issue or a throttle issue
Old Jun 20, 2020 | 12:55 PM
My4Fordtrucks
Not necessarily true. If the fuel pumps never shut off that is an indication that the computer is bad.
It has only been sitting for 3-4 months so the fuel quality shouldn’t be an issue.
Chris Skoglun
33
Apr 18, 2017 10:32 AM
truedouble
1997 - 2003 F150
Oct 24, 2012 04:27 PM
eriksf250
1978 - 1996 Big Bronco
Mar 7, 2007 05:58 PM
TotallyRoosted
1983 - 2012 Ranger & B-Series
Mar 22, 2004 04:55 PM
Jigsaw
Oct 18, 2003 09:45 PM
