Cleaning the undercarriage
Old Jun 18, 2020 | 09:35 PM
Rebekah82's Avatar
Rebekah82
One more question guys,
What is the best way to clean the grime from under the truck and under the hood?
Eagerly awaiting ideas,
Rebekah
Old Jun 18, 2020 | 10:50 PM
Pcmdub's Avatar
Pcmdub
Industrial Simple Green - Soak for 30 minutes but don't let it dry, and then pressure washer. For areas where grease is caked on, Oil Eater works good at full strength and use a soft brush.
After you are done, then go back and regrease all the fittings with a zerk gun.
Old Jun 19, 2020 | 12:02 AM
Christmas's Avatar
Christmas
Scrape off all the thick stuff before you even think of using chemicals and pressure washing.
Old Jun 19, 2020 | 08:11 AM
cbrown9064's Avatar
cbrown9064
Yeah, this. Saves a ton of mess later. Seems counterintuitive, but fastest.
Old Jun 19, 2020 | 08:35 AM
jsc83's Avatar
jsc83
I would be ready with seals and gaskets for fluid filled items under the truck. I found that the grime was helping to seal the rear differential and once I cleaned it, there was a leak.
I've been wanting to do the complete underside cleaning, but am holding off till I can get the seals/gaskets for the trans and t case, both of which are pretty caked with gunk.
Good luck.
Old Jun 22, 2020 | 05:49 PM
smoky_diesel's Avatar
smoky_diesel
This plus oven cleaner. Way more effective than any de-greaser I have used. Heck, don't need the pressure wash. I have a pressure washer and several de-greasers, but I just use oven cleaner and a regular hose, 10x faster.
HillBillyBuddha
13
Oct 3, 2013 02:42 PM
63' f100
Nov 1, 2009 12:07 AM
'03FordSVT
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 18, 2007 09:52 PM
ErrorS
13
Sep 30, 2007 09:40 PM
Mopey
Mar 27, 2006 08:15 AM
