I need some help. I took down the dome light to check the bulbs and put it right back. Now the dome and map lights don' work. The bulbs are good. To make matters worse, now my windows stopped working. I checked all fuses and they are good. I am lost. Does anyone have any ideas of what to look for?
I read a old post about issues with a flasher going constantly and was wondering if some one has a fix.Truck sat for a couple of weeks in damp weather but when I opened the door I noticed the flasher relay going.Started the truck and cycled the turn signals and flash and everything worked as it should but the flasher continued to go even with the key off I replaced the flasher but the same problem.Any Ideas.Thanks Tom
I read a old post about issues with a flasher going constantly and was wondering if some one has a fix. Truck sat for a couple of weeks in damp weather but when I opened the door I noticed the flasher relay going. Started the truck and cycled the turn signals and flash and everything worked as it should but the flasher continued to go even with the key off I replaced the flasher but the same problem. Any Ideas. Thanks Tom
You should start your own thread for your issue so as to not cause confusion with the issue in this thread.
