1978 - 1996 Big Bronco
Transmission Fluid Types
Old Oct 18, 2003 | 02:02 PM
89BroncoResto's Avatar
89BroncoResto
I have an 89 Bronco, 5sp w/overdrive. The tag on the fill plug says to use Ford ATF Type H only. What the heck is Type H? I think the trans is a little low, and would like to change the fluid before winter strikes. What should I get?
Thanks in advance from my Bronco!
Old Oct 18, 2003 | 02:20 PM
DW2455's Avatar
DW2455
Thats new to me, my 87" woth a C-6 uses DEXRON III/ MERCON i didn't know there was a type H. DW
Old Oct 18, 2003 | 04:52 PM
Schlump's Avatar
Schlump
In my '89 5-speed it calls for Mercon. The ATF I use is rated for both Mercon and Dexron and I have not had a problem with mine (108K). I send in oil samples for oil analysis and the analysis have always come back in good shape.
Old Oct 18, 2003 | 05:28 PM
89BroncoResto
What brand do you use, and how much does the trans hold? I've never put ATF in a manual trans before, so this is kinda wierd for me.
Old Oct 18, 2003 | 06:27 PM
Schlump's Avatar
Schlump
I use Valvoline, the transmission holds roughly 3.5 quarts. Get yourself one of those little hand pumps like you use for 90 weight, the kind that scews onto the oil bottle, and you will save yourself a ton of work!
Old Oct 22, 2003 | 08:27 PM
89BroncoResto
Well, I managed to change the fluid yesterday... Ford type H ATF is the Dextron Mercon III (The fluid removed from the trans was red). Thanks for all of the help!
Old Oct 22, 2003 | 08:59 PM
andym's Avatar
andym
You're lucky - the last time I drained a manual 5 speed, it was black. It wasn't a pretty sight.
Old Oct 22, 2003 | 09:04 PM
DanTana's Avatar
DanTana
I use Mobil 1 synthetic ATF, just like my motor oil. Costs a little more but I think it's well worth it for it's ability to handle thermal breakdown.
sfc11b
Bronco II
Aug 15, 2007 06:43 AM
sfc11b
Aug 12, 2007 08:04 AM
td351w
Aug 28, 2002 01:32 PM
foster0004
Aug 28, 2001 10:07 AM
