6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
AC Switch Wiring
Old Jun 16, 2020 | 01:24 PM
Texasjack1163's Avatar
Texasjack1163
AC Switch Wiring
Just did a 6.4 l engine swap and recharged the ac. I was moving an AC line around and the wires came out of the what i think is the high pressure switch connector. I plugged back the way I think they came out and the ac compressor does not turn on. I tried 2 different times and blew the 10 amp fuse in the fuse box under the hood.
Can anyone out there with a 2009 6.4 liter tell me what the colors are that go in the plug itself or take a photo. The plug has numbers on the backside corners from 1-4.
I have it plugged in the following sequence:
1. Gray wire with a yellow stripe
2. Gray wire
3. Green wire
4. Blue wire
Does anyone know to check the clutch diode that is in the underhood fuse box? It has a 1.0 on it.
Any help is appreciated.
Jack
Old Jun 20, 2020 | 11:16 AM
DieselDenny's Avatar
DieselDenny
Tex
looking at the clip side top.
left front Grey/yellow
right front grey
left rear blue
right rear green
Hope that helps.
Denny
kegger66
Jul 13, 2016 08:39 AM
agg_bagg
Sep 12, 2007 06:30 PM
rboeding
Oct 1, 2006 08:28 PM
akbg
Jun 16, 2004 08:56 PM
mpejsa
Mar 28, 2003 10:32 PM
