I am putting together a 79 f250 4x4 chassis to set my 78 body and engine in. I can not find 77 1/2-79 6cylinder engine perches for the 4x4 chassis. Is there any other perch that will work or Will work with some minor fabrication? Does somebody have the correct perches sitting on a forgotten shelf somewhere they would sell? Will FE perches from a highboy work? Im really trying to not have to fab perches from scratch.
4x4 Engine Perch Part Numbers
(Bracket, Engine Front Support) '77-'79 F250 Left: D7TZ-6029-E Right: D7TZ-6028-E
This is from the link 72rtchallenger posted.
Yes sir, but i know the upper frame flange bolt spacing is different between highboys and lowboys so that in itself changes the part number. Drilling one hole is not an issue for me. I just need a tower that will locate the engine properly on the chassis before the body is mounted. Im hoping to find a voice of experience in my odd situation. My research says 73-77 highboy 300/FE towers will work fine but im not 100% positive.
