1998 F250 LD 5.4 triton no spark
Old 06-14-2020, 08:05 PM
Mugly's Avatar
Mugly
Mugly is offline
Here's the story. I took the boat out on the water and when I returned to the boat ramp, the truck wouldn't start. After cranking it awhile it finally started to load the boat and get it home, just to never start again. I can say this truck has never left me stranded in 20 years, always breaks down in the driveway.
I tried to start it with starting fluid with no luck, so I figured it was a spark issue. I replaced all plugs and coil packs since its been 10 years since I had done it last, but still will not start. I took a plug out and grounded against metal in engine compartment and cranks engine over, no spark was generated on the plug.
My question is, what else do I need to check or replace that would be the culprit for no spark? I was told the crankshaft sensor could possibly be the issue or camshaft sensor? I'm not sure which ones this engine has or both and if a failure would cause no spark.
Ideas anyone?
Old 06-14-2020, 09:23 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
1. Check the Crank sensor for corrosion by unplugging and reseating a few times.
2. Does the fuel pump run when you turn the ignition On? Not looking for fuel but a power up issue.
3. Open fuse holder/ blown fuse because the fuse powers both the ignition coils and fuel injectors.
4. Computer power supply relay seating or fault.
Don't get complacent because we all will fail some time.
Your lucky you got 20 years.
Good luck.
Old 06-14-2020, 11:08 PM
Mugly's Avatar
Mugly
Mugly is offline
What fuses should I look at? I went through most of them and did not see any issues. I have relays but I don't know how to check those for failures. I can hear the fuel pump for a second or two .. Just isn't load, but I hear the buzzing
Old 06-15-2020, 06:12 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
There are no fuses that can cause a "no spark" issue without also causing collateral symptoms.
Did you verify that you have switched battery power on the COPs at the red wire when ignition switch is in RUN/START?
Observe the check engine light when the key is turned from OFF to RUN? Is it on (as it is supposed to be)? If so, crank the engine - does the check engine light go off and the tach register something during cranking? If not, then the PCM isn't picking up a crank sensor signal.
Old 06-15-2020, 09:21 AM
Mugly's Avatar
Mugly
Mugly is offline
I tried cranking engine over and tach doesn't move.
Old 06-15-2020, 10:44 AM
projectSHO89
Suggest making the COMPLETE set of recommended observations.
Old 06-15-2020, 11:01 AM
Mugly's Avatar
Mugly
Mugly is offline
I'm am not understanding this step. Please advise.
The check engine light does come on and when cranking the tach does not register anything. The check engine light stays on and never goes off before / during / and after cranking. The ABS light is the only light that turns off after cranking.
Old 06-15-2020, 11:22 AM
Bluegrass 7
To verify the Coils and Injectors are getting 12 volts, use a voltmeter. or at least a test light..
The Ignition has to be turned on to Run position because that fused power comes through the Ignition switch..
Forget the Tach on this issue. The motor has to run first.
If there is power to the Coils, the motor has to run in order to fire them. This is done by reference to the Crank sensor. If that sensor does not work, nothing else will work.
ABS has nothing to do with the engine control system. It too gets power through the Ignition switch so it's working if the self diagnostic are completing and Light goes out...
Old 06-15-2020, 02:16 PM
projectSHO89
The PCM is not seeing a signal from the crank sensor.
Old 06-15-2020, 09:15 PM
Mugly's Avatar
Mugly
Mugly is offline
I want to thank everyone who replied to this post. I just got finished replacing the crankshaft sensor and ol' red started on first attempt. So now I have a new sensor and plugs ans coils. My son is 15 and I plan on handing this truck off to him when he gets his license.. I just have afew more things I need to address before doing so.
Thanks again!
Feardeere7
19
05-08-2014 08:22 AM
copuntryboy
1997 - 2003 F150
03-12-2012 01:04 PM
johnnyhomz
1999 to 2016 Super Duty
03-15-2011 05:44 PM
johnnyhomz
2004 - 2008 F150
03-14-2011 05:13 PM
danny_g_76
1978 - 1996 Big Bronco
12-05-2005 10:01 AM
Quick Reply: 1998 F250 LD 5.4 triton no spark
