Running Lights
Old Jun 14, 2020 | 03:23 PM
kbmarsh88's Avatar
kbmarsh88
Running Lights
Greetings,
I have a 1979 F100 cab that has been installed on an F250 chassis from 1977. I verified everything worked on the 79 cab before I swapped it over. After chasing some electrical gremlins, I have one final problem - I have no front parking lights or turn signals. The truck has a flatbed, which i have wired LED brake, turn, and reverse lights into, and they all work on the rear end, but i have nothing on the front. The headlights work, as do the side markers on the sides at the front of the truck, but no turn or parking lights on the very front end. I have changed the bulbs, put dielectric grease, and tried sanding away some rust on the connectors, but i have nothing. When I engage the turn signal lever, the rear light illuminates, but does not flash. My next thought is a new turn signal switch, but I don't know if that will fix it. What about the canister relays (not sure what else to call them) behind the dash?
I appreciate any and all help you guys can provideprovide been lurking around, and have to day that this forum has helped a ton!
Old Jun 15, 2020 | 08:06 AM
rotating_equipment's Avatar
rotating_equipment
My '78 has the same issue. Swapped the headlight switch and now I have no running lights (tails, side markers, front parking). Probably a short behind the dash?
Old Feb 26, 2024 | 01:07 PM
garth's Avatar
garth
Rotating Equipment, did you ever solve this issue? I am having a similar issue, running lights work until I put headlights on then only headlights.
michael69
Jul 15, 2019 10:37 AM
twedt87
1997 - 2003 F150
Aug 30, 2016 11:57 AM
randomguy
Dec 31, 2013 04:23 PM
nateraz1
Dec 11, 2012 10:26 PM
77ford guy
Electrical Systems/Wiring
Sep 16, 2006 06:25 PM
