Sponsored by: Real Truck
7.3 PCM Help
Old Jun 10, 2020 | 08:56 PM
Hog73's Avatar
Hog73
7.3 PCM Help
Hello all,
I got my Hydra chip the other day. Today i tried to get the PCM out, but the part in the engine bay where there is supposed to be a plastic box with one 10mm connector bolt, well my truck has 3 bolts vertically. I tried getting just the center one undone. I pulled the plastic case and metal bracket out from under the dash, but the PCM wont budge.
i try moving it to the right and pulling back. Nothing.
i have a 2000 f350, plow setup. Should i take all 3 bolts off? The pcm is loose when moved left and right, but it wont budge forward or back
Old Jun 10, 2020 | 10:11 PM
Evan_P's Avatar
Evan_P
Those are not the right ones. Look lower and closer to the fender should be one single large connector with a 10mm bolt in the middle.
Cole Eakle
Nov 21, 2018 02:50 PM
PNW350SD
Oct 4, 2016 03:24 PM
man-o-war
Oct 10, 2015 03:59 PM
quality1construction
Mar 5, 2008 10:21 PM
