2020 Steering
Old Jun 10, 2020 | 07:32 PM
JARED_LA's Avatar
JARED_LA
2020 Steering
2020 F250 6.7, 2700 miles. Was on a long drive today and truck had a hard pull only at highway speeds. Once I made it to the local slower speed roads, the pull disappeared. Steering was definitely harder turning left vs right. Is this the norm for the new steering?
Old Jun 10, 2020 | 07:36 PM
Ding126's Avatar
Ding126
Im going to say not normal. Have you checked tire pressures manually with a gauge? I'm Guessing a tire issue, a crown in the road or front end alignment to start with.
Old Jun 10, 2020 | 09:14 PM
Sailor#10's Avatar
Sailor#10
You didn't, by any chance, have 4wd engaged??
Old Jun 11, 2020 | 05:20 AM
JARED_LA's Avatar
JARED_LA
No sir. It felt similar to my 2015 when I installed a Fox SS and the pressure was too high causing a right pull.
Old Aug 25, 2020 | 10:15 AM
JARED_LA's Avatar
JARED_LA
Still having this issue after 2" level, Kelderman SS, alignment and 2.0 caster cams installed. I removed the dual SS and it was worse....almost seems as if it is the electric steering adjusting for crown of road.....
Old Aug 25, 2020 | 10:47 AM
jollyrogr's Avatar
jollyrogr
Do you have adaptive steering?
Could be tires? Apparently Goodyear pulls to the left...
Old Aug 25, 2020 | 11:12 AM
JARED_LA's Avatar
JARED_LA
No adaptive steering....
Old Aug 25, 2020 | 11:24 AM
Ding126's Avatar
Ding126
what are you air pressures and type of tires?
Now the term " pulling " to me is when brakes are applied and the truck pulls left or right.. But driving and the truck "drifts left or right " can narrow down your issue
Old Aug 25, 2020 | 11:37 AM
JARED_LA's Avatar
JARED_LA
Factory Michelins, 55psi all 4
Old Aug 25, 2020 | 11:53 AM
giveitago's Avatar
giveitago
Trailering
[QUOTE=jollyrogr;19448867]Do you have adaptive steering?
Could be tires? Apparently Goodyear pulls to the left... [/QUOTE
Old Aug 25, 2020 | 11:58 AM
ford390gashog's Avatar
ford390gashog
Okay my 2020 has the same issue but only randomly. The pull is to the left and if you turn the wheel right there is very little effort required. The dealer was able to duplicate it and the Ford helpline has instructed them to replace the box and the electric assist. The parts are on back order until November until then I was told they reset the module and to drive it. The issue has happened a few times since and it feels like a low tire would, it grabs and pulls rather hard. The worst so far was when exiting at highway speed and the truck want to pull me into the other lane.
Old Aug 25, 2020 | 12:08 PM
JARED_LA's Avatar
JARED_LA
That's exactly my issue, except mine is right....How do you reset the module?
Old Aug 25, 2020 | 02:56 PM
Mike_in_STL's Avatar
Mike_in_STL
Nicely played...
Old Aug 25, 2020 | 03:50 PM
mtnguy's Avatar
mtnguy
OK, that is just plain funny !!
Old Aug 25, 2020 | 03:53 PM
JARED_LA's Avatar
JARED_LA
No Goodyears for me! BTW, I have an appt on Thursday morning...will keep this post updated....
Whitetail2017
Apr 26, 2022 12:35 PM
black08
Oct 12, 2018 10:45 AM
magum350
Oct 23, 2011 01:04 PM
ericdes
1983 - 2012 Ranger & B-Series
May 30, 2011 12:24 AM
afinepoint
Feb 25, 2008 02:10 PM
