Do these work? I like the concept of a bottle jack/jackstand but every review I read says the way it's constructed causes the jack stand to be torqued away from the bottle jack as it's lifting and it eventually ends up breaking the connection between the bottle jack and jack stand. Seems like it would need a 2nd bottle jack on the other side as well to lift the jack stand smoothly without binding.
I’ve had a couple of these for a few years, they work pretty good for me. Never had any issues, except they aren’t the best at going down without a load. I usually use them with the 4 post lift and a jack tray, they work great for that. I can see where there might be issues with separation if you load them up, 3 tons is a pretty optimistic number. Don’t think I would try that much, I doubt that I’ve had a ton on any jack at a time.
For heavier lifting I have an assortment of bottle and floor jacks. My favorite floor jack is my 3 ton Daytona from HF, they are nice. If I need to carry it around, I have a 1 1/2 ton aluminum Craftsman that I’ve had for probably 30 years.
EDIT: I was just on the HF web site and noticed that they now have numerous Daytona jacks of all different colors. The yellow one is the one I have, low profile, high lift. Not sure about the other colors that are much cheaper?
You get a scissor jack from an RV shop with a hex drive head. You stick your impact gun on it and pull the trigger. The scissor jack is infinitely lighter than a floor jack, and with a gun on it, it’s infinitely faster. Use cribbed 6x6 timber’s instead of jack stands. They’re infinitely more stable and can handle 10x the load of a normal jack stand.
You're kidding right? Those scissor jacks are mousetraps and putting an impact on them destroys the screw because they're not designed to turn that fast. Guess what happens when the screw fails? Whatever you have lifted falls down. 10x the load? Hardly.
This is the one Snap-on tried suing HF for patent infringement but the case was settled out of court after HF pointed out that the Snap-on jacks are also made in China in the same factory.
+1. I have the same. If you are shopping for it, make sure to buy the Super Duty version, only comes in yellow currently. It's the most expensive one they have. Don't be fooled by the other 3 ton versions. They are probably fine but if you want the biggest/heaviest one, get the Super Duty version.
Wood cribbing is used when you far surpass the capacities of any jackstand out there. Yes, 10x the load of a 3 or 6-ton jackstand is EASY to achieve with 6x6 cribbing...
I have a Torin BigRed Service Jack which cost me less than $200 at PepBoys. While I haven't had a need to lift my truck with it yet, the reach and load capacity of it should be more than capable while still being able to get under most cars. I also agree with all the comments about jack stands...your life is not worth risking if a plunger seal goes out or the release gets triggered.
I misread Fracture's post. Wood cribbing is a superior support method. I read the post as saying the scissor jack had 10x the capacity of regular jackstands which it most certainly will not. I stand by my statement of not using scissor jacks with impact wrenches, but fully support using cribbing to support a vehicle while lifted.
I recently did some research on the best floor jacks and found that all chinese made floor jacks are not rebuildable and a single O-ring is the only thing preventing the jack from failing and dropping the load if that O-ring fails. The old jacks of yesteryear are good safe floor jacks, once they began manufacturing overseas is when the quality and safety took a dive.
Only a USA made jack is worth the money and can be trusted as an everyday use jack. They can be repaired if something fails. The Chinese made garbage is a purchase and replace item. Anything made by Hein-Werner or any jack that has been rebranded that is made by Hein-Werner is a quality jack. I think Lincoln was an old name that was made by Hein-Werner
