1964 alignment specs.
Old Jun 9, 2020 | 09:47 PM
bmuhlbach's Avatar
bmuhlbach
put new king pins in .Now want to get a alignment done. I took it in the other day. they checked it out toe was out. Guy said he couldnt find any chart to check alignment. so waste of morning Made another appoinment at another place would like to have info. if they cannt find any. Its a 1964 Econoline van h.d
Old Jun 10, 2020 | 08:32 AM
jschira's Avatar
jschira
Here you go.
File Type: pdf
Old Jun 10, 2020 | 10:43 PM
bmuhlbach's Avatar
bmuhlbach
thank you for the spec. sheet
Old Jun 11, 2020 | 05:49 AM
jschira's Avatar
jschira
No problem.
Old Jun 11, 2020 | 02:58 PM
Beechkid's Avatar
Beechkid
Ahhh, just an FYI....those specs are for bias ply tires...which is all fine if you are running those now, if you are running radials, the specs are different (and will be squirly with the bias ply tire specs).... such as with the mustangs, I used the 1970 specs IIRR as those came with radials... might do a little R&D and comparison between early & late model specs using the same chassis.
Old Jun 11, 2020 | 06:15 PM
EmilBarnabas's Avatar
EmilBarnabas
That spec sheet came from this web page. Econoline Front Axles
if you try to align your self, be sure to drive the Econoline forward and stop, then do your measurements.
Old Jun 12, 2020 | 10:29 AM
bmuhlbach's Avatar
bmuhlbach
will back from shop andddd the bar is bent that connects the tie rod end. its bend by the threads of pass side tie rod. wont adjust or he wont in fear of threads stripping. what is the name for this bar. I think I can get another hope its not bend too. Then try to straighten my original. called green sales they dont have a nos.. guy did say toe is 2 degrees out so that is my issue I believe
Old Jun 12, 2020 | 11:32 AM
Beechkid's Avatar
Beechkid
Originally Posted by EmilBarnabas
That spec sheet came from this web page. Econoline Front Axles.
Yes, I looked at it but, it does not state if those specs are for bias ply or radial tires..... and there is a difference... enough to make the vehicle unstable at speeds well above 30 mph and create uncomfortable steering issues at speeds not exceeding 30 mph
Old Jun 12, 2020 | 08:03 PM
EmilBarnabas
Those alignment specs are from the Sixties, so it is for Bias Ply tires. I use those same specs for Radials.
sunnyboy1212
Oct 1, 2013 07:31 PM
dcrahn
Jun 22, 2013 11:32 PM
SpeedE55
6.4L Power Stroke Diesel
Feb 27, 2008 03:02 PM
dstruble
Apr 24, 2006 12:15 PM
