2003 EB 7.3 - clock spring / ABS
Old Jun 9, 2020 | 11:21 AM
Macmathews's Avatar
Macmathews
2003 Ex - EB -7.3 Cruise only on Steering wheel.
Have airbag light and No cruise control ..
ABS also activate's at full stop almost constantly.. (annoying to say the least)
Is there a relation between Block spring and ABS system ?
What are thoughts about ordering Non OEM replacement clock spring ?
Thanks as always team
Kyle
Old Jun 9, 2020 | 02:45 PM
6_Myles's Avatar
6_Myles
Have you checked the ABS sensors and/or tone rings? I just went through some minor ABS issues and did a decent amount of searching and didn't see anything on clock springs being a culprit...not saying it isn't, but most of the other non-cruise control issues I saw were either bad ABS sensors/wiring...or in my case i had a piece of metal somehow get attached to the end of my sensor and it read the tone ring incorrectly.
Old Jun 9, 2020 | 03:16 PM
palacios289's Avatar
palacios289
Macmatthews, I just swapped my clockspring with a Dorman unit. So far so good. It was $130 new from advanced autoparts.
Old Jun 9, 2020 | 04:52 PM
Macmathews's Avatar
Macmathews
What truck is that for ?
Steering wheel cruise ?
Steering wheel radio ?
I've only seen them for like 185$
Kyle
Old Jun 9, 2020 | 08:08 PM
palacios289
Mac, mine was for a 2000 excursion with cruise control only.
Old Jun 10, 2020 | 02:44 PM
CousinCarl's Avatar
CousinCarl
Dorman clock spring in my F350 since Jan 2019, no issues.
RA has it $117 https://www.rockauto.com/en/parts/do...ckspring,10480
Old May 16, 2021 | 03:24 PM
Macmathews's Avatar
Macmathews
So to bring this back to life..
I DO NOT remember now how I fixed my ABS issue (but that was corrected ) but I still ho cruse control..
Well today I installed a used clock spring from my brothers Burnt truck..
I got my horn back and the airback light went out..
But STILL NO cruise .. I was suprised and disappointed ..
Thoughts ?
Kyle
Old May 16, 2021 | 05:19 PM
4wheelexcursion's Avatar
4wheelexcursion
Clockspring
I had this same issue with my 03EB with the 6.0. I was not able to find a clockspring from any supplier. The part number is:
2C7Z14A664AC. My EB has the radio/ HVAC/as well as cruise. My search finally landed me to a used one from someone on this site! But my search did not end there. I was able to find a new old stock on EBay. I have that put away if and when the used one goes bad. Good luck on your search, this is a tough part to find!
Old May 16, 2021 | 06:12 PM
Macmathews's Avatar
Macmathews
Na i think mine is other than clock spring issue..
the one u removed was the same as i just installed.
tomorrow i find out about pressure switch..
hopefully it's that
Old May 26, 2021 | 06:22 AM
Macmathews's Avatar
Macmathews
I just replaced the recalled part under the master cylinder (pressure switch)
Still no Cruise control..
I hooked up the Laptop and ran KOER and got code
P0571 - speed control brake switch circuit failure
I cannot find much with reference to the above.
Kyle
Old May 29, 2021 | 02:54 PM
Macmathews's Avatar
Macmathews
Kyle
So just tried a PCM out of my brother 03 with same cruise control and no luck , so I'm thinking this issue is with the controls on the steering wheel.
Kyle
Old May 30, 2021 | 06:15 AM
01__Excursion's Avatar
01__Excursion
did you check the brake pedal switch?
Old May 30, 2021 | 06:17 AM
Macmathews's Avatar
Macmathews
I have not , where is this ?
Kyle
Old May 30, 2021 | 09:24 PM
01__Excursion
From the break pedal, follow the arm up, till you see the switch. I'm guessing that might be throwing the P0571 code..
sand_fiend
Apr 25, 2020 04:06 PM
daveinliberty
Oct 1, 2008 06:52 AM
