Battery discharging?
Old Jun 8, 2020 | 10:39 PM
DriverD's Avatar
DriverD
'97 E150, 5.4L
New battery and alternator, but if I leave the van in the driveway for three or four days the battery goes dead. Today, after sitting for a week, I measured 1.5V! This is probably what killed the last battery.
What would you say are the likely culprits? Stuck relay? Bad starter solenoid or starter? Leaking regulator?
I guess I'll just leave the negative lead disconnected until I need the van.
Old Jun 8, 2020 | 11:19 PM
michaeldiaz94520's Avatar
michaeldiaz94520
Same
I have the same issue
let me know if you figure it out
mines 91 e150 , 5.0 gas
maybe interior light ? I just don’t know I hate it
Old Jun 9, 2020 | 02:43 AM
seville009's Avatar
seville009
Had a 2011 F350 that had a sudden quick battery drain issue a few months ago. Couldn’t figure it out. Had the Ford dealer look at it; was broken wires somewhere. Fixed and works fine now
Old Jun 9, 2020 | 04:14 AM
JWA's Avatar
JWA
If the batteries were brand new, installed and the vehicle not run as a daily driver the small residual charge in the battery when new isn't enough to sustain a week or more of no charging from the alternator. Its highly helpful to check and note the CCA reading of the new battery.
There might also be some sort of parasitic drain causing this---there are numerous YouTube videos on this topic. I have two favorites but most are good enough to help determine if this condition exists. Depending on your skill or experience with automotive electrical systems determining this is either easy or a bit more complex than some are willing to dig into. It does require a digital multi-meter that can read in the milliamp ranges.
HTH
Old Jun 9, 2020 | 09:39 AM
DriverD's Avatar
DriverD
I brought the new battery home and charged it before installing. 750 CCA. After charging yesterday the load test says it's good.
Somehow the battery in my Toyota can hold a charge for a few days if the car is not driven.
Oddly enough, I measured across the two main power leads. The resistance slowly climbs to 1500 Ohms in normal polarity and 350 Ohms in reversed polarity. This suggests some sort of reactive load. I have a good Fluke meter and the EVTM. What I don't have is the time and patience to test every circuit. I'll just leave the common lead disconnected until I need to drive the van.
Old Jun 10, 2020 | 03:05 AM
JWA's Avatar
JWA
If you won't perform a parasitic draw test then you're left guessing what's really going on. You choice, not my van so best of luck!
Old Jun 10, 2020 | 10:58 PM
DriverD's Avatar
DriverD
I was hoping that someone with more experience might point me to what has been known to cause this not just point me to YouTube where most videos jam five minutes of useful information into 30 minutes of video.
Old Jun 11, 2020 | 04:44 AM
JWA's Avatar
JWA
You seem to be hell bent ignoring the information help offered so far so not sure trying to help you is worth the time or effort. I've had battery issues 100% due parasitic draw, diagnosed it with a known technique, found and repair the problem in about 10 seconds.
Best of luck on solving your issue!
Old Jun 11, 2020 | 05:43 AM
seville009's Avatar
seville009
Unfortunately, there is no easy answer. As JWA says, your only choice is to do the work
I mentioned in my post above about my parasitic draw issue. I attempted to find it myself, but I’m not a mechanic or electrician, so quite frankly didn’t trust my own work. Needless to say, I was not successful.
Took it to the dealer; they found the issue in a day. Problem was a fee broken wires somewhere. In yhe end, it may be easier to pay someone to do it for you
that being said, I had bookmarked this video when I was messing around with it. Might help.
Old Jun 14, 2020 | 07:00 PM
DriverD's Avatar
DriverD
Okay I found the time to check it out today. The initial draw was almost an amp, settling at 0.3A after a few seconds. Removing fuse #8 from the power distribution box left the draw at a normal 15mA. This fuse feeds 8 fuses in the interior fuse panel. I removed fuse #4 to disable the door switch, as there is no easy way to hold it closed while the door is open.
I found the leak at fuse #17. The odd thing is that this fuse is, "not used."
This is an Explorer conversion van. I have no idea what they might have put on this circuit, and they're not telling. I did notice when I started the van that the radio is back to its mystery behavior of coming on, showing volume on the bar graph, but making no sound.
Old Jun 15, 2020 | 06:40 AM
bengineer's Avatar
bengineer
I finally had to disconnect the factory radio in my 2000. It would come on ramdomly even with the key off. The van would sit a day then I'd walk by and hear the radio playing. Would drain the battery. After pulling the fuse, battery life if back to normal.
Old Jun 15, 2020 | 10:23 AM
DriverD's Avatar
DriverD
I need to check out what accessory Explorer might have connected on fuse #17. There's an entertainment system in the back, separate radio, TV with DVD player, etc.. There's also a CD changer which cannot read discs. All this stuff is on a separate fuse box in back.
Old Jun 16, 2020 | 12:29 PM
DriverD's Avatar
DriverD
The mystery deepens. I went out for a drive to complete a drive cycle. The van ran nicely. But, when I got home and connected my scanner the OBD socket was dead. How could removing a fuse which is, "not used," cause this?
Old Jun 17, 2020 | 04:45 AM
JWA's Avatar
JWA
The OBD-II date link connector is fused off the power port or cigar lighter power supply--check and replace those as needed.
You honestly need to find an EVTM for your year and model van or at minimum the Owner's Manual which has a fuse chart and rating section for DIY's. That is NOT a substitute for an actual EVTM but its better than guessing.
Old Jun 17, 2020 | 05:54 AM
seville009's Avatar
seville009
the linked thread has posts with links to various fuse box diagrams in case one of those helps
https://www.ford-trucks.com/forums/1465793-fuses.html
