Rocker Arms
Old Oct 8, 2021 | 12:46 PM
wwhite's Avatar
wwhite
Originally Posted by Ksz15252
I'm building a 351w roller with E7TE heads. Running stock dish pistons, rods and crank all new bearing and rings. Running a Motorsport F303 cam lifters and matched springs. I have ordered a set of 1.6 full roller rockers from proform pedestal mount . I am trying to figure out what pushrods I am going to need. The stock measure roughly 7.5. The block and heads have not been shaved. Any help is appreciated.
See thread over here: New aluminum heads, need rocker advice - Page 2 - Ford Truck Enthusiasts Forums (ford-trucks.com)
You will need a pushrod measuring tool.
I went through this, and figured out that the F4TE cam has a large base circle, the cam I ordered has a standard base circle, and some cams come in a small base circle.
When you get a pushrod measuring tool, also buy the soft valve springs, will make life easier.
dsc
16
Feb 3, 2012 07:30 PM
Greg Blackmon
Dec 26, 2008 04:10 PM
STGFordCrazy04
Jul 27, 2007 06:59 AM
mauicruza
Apr 20, 2006 05:58 AM
rog_j
15
Oct 28, 2004 08:33 PM
