Need help with my e40d
Old Jun 7, 2020 | 12:19 PM
Chrismackhk's Avatar
Chrismackhk
Need some help guys have a 97 f350 7.5 2wd transmission took a crap on me does any one know what models and years have a comparable e40d thanks in advance
Old Jun 7, 2020 | 01:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Any 1995 to 1997 F-Series or E-Series 4x2 with a 7.5L is compatible. Nothing else is. An earlier trans from those models would be compatible if you change the solenoid body to a 1995 or newer.
Old Jun 7, 2020 | 02:38 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
'Took a crap' is kinda vague is there any chance of rebuilding it? What happened to the poor thing?
Old Jun 7, 2020 | 04:31 PM
Chrismackhk
Probably can rebuild it but costs to much to have it done.i know absolutely nothing about transmission so trying to find one at a you pull it,so if I find say a 78 with a 460 I can use the transmission if I change the solenoid pack out?thank you btw.
Old Jun 7, 2020 | 04:41 PM
JJF20's Avatar
JJF20
I don’t think they starting making the e4od until the late 80’s.
Old Jun 7, 2020 | 05:19 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
1989. However you don't want it (far too many internal weaknesses and you need an expert among experts to fix them correctly. Even half of those select few, will tell you not to bother lol. I just made that last part up, though I wouldn't be surprised if it were true.) Look for a '90-94 and swap the pack or a 95-97 for direct replacement.
Old Jun 7, 2020 | 07:48 PM
Da_Lariat_Chariot
It's rare that without doing some diagnosing and some teardown that you can just condemn the transmission from the outside and actually be right about it ...
Old Jun 8, 2020 | 11:58 AM
rla2005's Avatar
rla2005
This.....
Far too many times someone has replaced their E4OD to find the problem still exists.
What are the symptoms and what codes have you gotten when running the Key On Engine Off (KOEO) tests and Stored Code display?
kris81
Louisiana Chapter
Sep 10, 2010 12:43 PM
76f350spercamprspeal
S. California Chapter
Apr 3, 2010 05:48 AM
exidenick
Tennessee Chapter
Jan 19, 2010 07:50 PM
derekf
1997 - 2003 F150
Feb 24, 2000 08:10 AM
