T86E-IN part needed
Old Jun 6, 2020 | 03:04 PM
bwl85248's Avatar
bwl85248
T86E-IN part needed
Need the front bearing retainer for a Warner T86E-IN transmission connected to a Warner R10F-1C overdrive. It was original equipment on 63 Ford F100 that I am trying to bring back to life. The truck version has a larger diameter on the snout part since it has to clear the 1-3/8" input shaft. The correct Ford part number for this retainer is B7C-7050-A. It will have three mounting bolt holes, and probably have "T86-??" cast into it. So far no luck finding it using parts suppliers that come up on Google. Suggestions on where else I can look are appreciated. Thanks
File Type: pdf
Old Jun 7, 2020 | 07:17 AM
hiball3985's Avatar
hiball3985
Transmissions and Transfer Cases
Old Jun 7, 2020 | 10:13 AM
bwl85248's Avatar
bwl85248
Thanks for the recommendation. I sent them an email.
rodguinto
New Member Introductions
Jan 18, 2016 03:02 PM
rbf
May 22, 2001 05:19 PM
