Sponsored by: Auxito
2002 4.6 differences
Old Jun 6, 2020 | 02:23 PM
Jason Epperson's Avatar
Jason Epperson
What are the differences in the 4.6 engines built in 2002? They call for 2 different head gasket kits. This is the code W Romeo I am referring to. The ones built after October are different than the ones prior? Thanks in advance.
Old Jul 1, 2020 | 07:51 PM
John Padgett's Avatar
John Padgett
not that i know of
5.4 or 4.6 1997-2020 with stock bore are the same
i think 2v 3v 4v use same bore as well
there may be water passage differences but i doubt it
Old Jul 6, 2020 | 02:14 PM
Stonedpony's Avatar
Stonedpony
Depends on what heads are on those two engines. One calls for a thicker head gasket than the other even though they are both W Romeo engines. You need to get the number off the heads and have Ford tell you if they are the same or which one uses which head gasket.
Most head gaskets for the 4.6 are 0.03 to 0.06 in thickness depending on who made them and all that goes with that. Now there are those that go to around 0.12 thickness as well. Even if the engines are 2002 engines, that does not mean the heads are.
tshannahan
2004 - 2008 F150
Apr 20, 2006 02:17 PM
radar_ridr
Modular V8 (4.6L, 5.4L)
Mar 15, 2003 08:39 AM
