Sponsored by: Real Truck
AC Problems
Old Jun 5, 2020 | 04:45 PM
jimw1221's Avatar
jimw1221
AC Problems
I have a 2011 Ford F-250 Super Duty 6.2L Larit.. package and I had it in for ac repairs three different places but they can't seem to fix it. The Ford dealer in Ruston, LA told me that it is the Expansion Valve. I had it replaced, but that didn't fix it. So when I got home i took it to another Ford Dealer. They told me it needed a AC Compressor Kit with Condenser and the system flushed. So I told them to go ahead and fix it. It was turning cold so I really didn't have a chance to check it out last winter. Now that the weather is heating up, I turned the AC on and it blew cool air for about three minutes and again started blowing hot air again. I turned the temp down to 70 degrees and it would cycle between cool (not cold) and hot. This has cost me a fortune and it is still not fixed. Can anyone on the forum please tell me what could be the problem. By-the-way, they all hooked it up to million dollar diag. machine.
Thanks in advance,
Jim
Old Jun 6, 2020 | 05:46 AM
projectSHO89's Avatar
projectSHO89
Take it back to the dealer who last worked on it.
Old Jun 6, 2020 | 06:02 AM
seville009's Avatar
seville009
If you have an a/c shop nearby, take it to them for a diagnosis, as they might have more knowledge than the dealer’s mechanic.
Bring your Ford receipts with you so that you can show them what’s been done. If they say the Ford dealer didn’t repair what needs to be repaired, just have the a/c shop fix it - probably cheaper than the Ford dealer anyway since presumably nothing is under warranty at Ford
Old Jun 6, 2020 | 02:19 PM
1`badgt500's Avatar
1`badgt500
On my 99 my AC was doing the same thing after a shop replaced a schrader valve. It ended up that the tech didn't put enough refrigerant in the system.
Old Jun 7, 2020 | 08:30 AM
chasracer's Avatar
chasracer
So you have had the compressor, condenser and expansion valve replaced with new parts, system flushed, vacuumed and refilled with the proper amount of oil and refrigerant? Something tells me that the last dealer didn't pay attention or didn't perform the flush procedure correctly or at all. This is a classic case of the system having junk in it and plugging up the expansion valve.
Old Jun 7, 2020 | 11:36 AM
Lance Kohler's Avatar
Lance Kohler
orifice tube filter
we have a 99 had same issues, did anybody check your orifice tube filter?
pencilpusher865
Mar 3, 2018 08:00 AM
Big Norm
1997 - 2003 F150
Sep 16, 2013 09:53 PM
wellstroked
6.7L Power Stroke Diesel
Apr 25, 2012 04:43 PM
CJF150
2004 - 2008 F150
20
Jul 7, 2004 08:24 AM
jameslaz
Aug 1, 2003 09:55 PM
