460 Balancer Timing Question
Old Jun 1, 2020 | 10:47 AM
Deerhunter4's Avatar
Deerhunter4
Does the 460 balancer have a tendency to move in relation to TDC like I’ve seen on the 351m/400 balancers? The reason I ask is I just got a new project with a 460 and I’m checking/adjusting timing and right now I’m seeing about 15 degrees initial and that seems a little high? The truck has Atomic EFI and a Flamethrower distributor and coil. It seems like it wants more timing so I bumped it to 18 degrees initial and did a test drive. No pinging and much better response and it still starts easy. I’m going to keep adjusting but I was just wondering if the markings on the balancer could be off and it may be less timing than what I’m reading off the marks.
Old Jun 1, 2020 | 02:28 PM
Bruce W.'s Avatar
Bruce W.
FWIW, I've been running my '97 F350/460/ZF5 at 16-20 degrees for the last 100K or so. The only time it will ping is if I lug it...so I don't lug it. It is doggy at the factory 10 degrees. Better snap and gas mileage at the 16-20 degree setting. If I really worked it, I'd back off timing a bit.
Old Jun 1, 2020 | 02:57 PM
Deerhunter4
Thanks. Mine will never pull anything but it is a 1979 F250 4wd with 35” tires so it’s loaded pretty good. I do think it has 4.30 gears which helps a lot. I’m going to try 2 more degrees and see how it goes.
fdude64
Aug 18, 2008 08:30 PM
hotrodmerc
Jul 24, 2004 11:03 PM
460linc
Mar 3, 2004 10:31 AM
F250SC
Dec 14, 2003 11:51 AM
