Headlight switch 1951 ford f 1
I am working on wiring my 51 f1. I switched to a 12 volt system with a modern gym type column. I have a 12 headlight switch but the wiring diagram that came with it is a bit confusing. It’s supposed to control lights on and off by pulling out ****. However nothing on the wiring diagram speaks to the headlight wires. It has all sorts of other connections, which I probably won’t use, as most of those go through the new harness fuse box. So not sure which of these posts the lights wires go to. Attached is the headlight switch wiring diagram. Sold by mid fifty.
You weren't specific on "lights wires" so I just assumed you were referring to headlights because they aren't included in the pinout. The wiring for the dimmer switch is the same as the original, and includes the headlights, if you have the schematic. Or maybe I should say - the "dimmer" IS the headlights.
Man. Wiring is the most confusing.
so if I understand you The rear lights is the same pin I put headlights on (R). Makes sense when I pull the **** it would turn on the rear taillights and headlights. For what I understand the dimmer is the dash light dimming control. High beams would be controlled through column.
Those instructions were written by someone that doesn't have a full understanding of automotive wiring, ie: "amp gauge". Huh? Technically, no such thing exists in the free world. A meter is an instrument that measures things, in this case it measures amperes - ammeter. A gauge is an instrument for determining or regulating the level, state, dimensions, distance, or capacity. Literary license has given way to colloquialisms. But I digress.
Ok thanks for taking the time to help. Me with this.. so after reading your post i did some looking at my stuff.
So seems that my column does not have headlight dimming feature. I will have to rely on the foot switch...
So i will go through how i think it should be wired and you can tell me how wrong i am.
headlight wires high/low from harness go to my floor dimmer switch. Dimmer Has 3 connectors 2 for high low....and 1 that says battery.
I am thinking the battery post goes to the light switch that says dimmer “h”. Then the Light switch Battery Amp “B”. The only thing i am not sure off, unless some of this is wrong, is that my wiring harness Performance World 329021 came with what they call a headlight breaker. Picture attached. No idea what to do with it. There is 12v 30amp stamped on it. But nothing that i can see to plug it in....
Can I assume at this point that you are using the original Ford foot switch then?
Headlight wires high/low from harness go to my floor dimmer switch.
That would be the original front clip harness - correct?!
Foot switch has three terminals: High beam, Low beam, And feed from light switch "H" terminal (red wire with yellow tracer).
To me that's a confusing statement, but I believe I explained it above.
tjc transport
Electrical Systems/Wiring
38
11-20-2019 06:06 PM
Blue_Betty
08-15-2010 07:44 PM
barebackjake
11-21-2004 10:22 AM
78f250lj
07-03-2002 06:21 PM
