I have a 93 idi and I want to know the best way on how to adjust the timing because my rpms at idle are a little higher than normal.
Also my TPS is way off. I dont know if it has to do with the timing. But the voltage is way off. It is actually backwards. If I try to adjust it from where it's at now the overdrive light will start flashing and the trans will go crazy.
I have tried everything I know to try and diagnose it as well as other forums and I'm at a stand still.
Idle speed is adjusted right there on the side of the ip using a screw driver. Look where the accelerator cable hooks and you'll see the adjustment. You want to adjust that with a warm engine, after the cold idle advance is turned off. Once that is set, then you can set and adjust the TPS.
