88 bronco driveability
Old Dec 26, 2004 | 12:34 PM
armoredcar's Avatar
armoredcar
Recently changed thermostat, water pump, and adjusted timing. The timing was way off, around 25 degrees BTDC I used a timing light and set to around 10 BDTC it idles a lot better but now has no power. Does anyone have a clue?
Old Dec 26, 2004 | 12:42 PM
tex94F250's Avatar
tex94F250
Pull your codes! See www.fordfuelinjection.com. If someone set timing up that far it should have been a little sluggish to start when hot and they were compensating for a lack of computer adjusted timing, perhaps. How did you check your timing?
Tex
Old Dec 26, 2004 | 03:27 PM
armoredcar's Avatar
armoredcar
Before I adjusted the timing the initial idle when cold was 2000-2500 rpms that is why I adjusted timing. When I adjusted the timing I did remove the spout connector before adjusting and then reinstalled afterwards. One person said it could be the TPS, but I dont think this would all of a sudden be effected by adjusting the timing.
Old Dec 26, 2004 | 03:31 PM
armoredcar's Avatar
armoredcar
Also there is an aftermarket ignition coil installed. I just remembered.
Old Dec 26, 2004 | 04:09 PM
tex94F250's Avatar
tex94F250
If it was the TPS it may have coincidently failed. In adjusting the timing you have changed the way your computer looks at things. This would be a good time to reset the computer.
Tex
Old Dec 26, 2004 | 04:17 PM
armoredcar's Avatar
armoredcar
How do I do that?
Old Dec 26, 2004 | 04:34 PM
tex94F250's Avatar
tex94F250
Initially disconnect your negative battery terminal and let it sit for about 5 minutes. This is actually a great time to clean both terminals/clamps by the way. Re attach and start engine. Pull any codes from the CEL (check engine light) but all should be cleared. Check www.fordfuelinjection.com.
Tex
