Trailer Running Lights Not Enabled - Help!!
Y2KW57 Now that I have tried another truck I will try some diagnosis myself. I have zero experience with LED's, but I do assume if I apply 12v to the running light circuit they should light. I'll go from there. Trailer is new to me. Super sanitary wiring job you did, Bravo!
"They tested and worked on the trailer for hours"
It is doubtful that they would have invested all these hours, multiplied by the number of men working on it, if they did not themselves suspect that their work was the cause of the trailer lights not working. Whether they voice this suspicion to the customer... or not, so as not to undermine customer confidence in their competency, that is an awful lot of manhours, for a business whose principle commodity is labor, to just give away. I think they knew they might have messed up, even if they didn't know how they messed up.
LIFO is an accounting term for Last In First Out that applies equally well for electrical and mechanical diagnosis. The last thing changed prior to the fault discovery, should be the first thing examined after the fault is found.
The Tremor wasn't changed. The trailer was. That leaves the trailer as Suspect #1.
"but I do assume if I apply 12v to the running light circuit they should light"
As long as there is also a continuous ground return path to the same direct current power source that is supplying the 12V to the running light circuit... otherwise, they won't light.
The importance of a good ground cannot be over emphasized, so I'll reiterate this again, despite member Morbus already saying it earlier.
In my trailer harness connector wiring project above, I extended the Ford supplied ground circuit to two posts, bridged by a hand fabricated ground buss bar that electrically linked the posts, and further adding a ground jumper to the frame.
To summarize the suggestions illustrated by the combination of responses and illustrations,
1. Ensure that the designated function of circuits are located in the correct receptacles within the trailer end's connector.
2. Check the continuity and physical integrity of each circuit on and under the trailer
3. Take whatever time is needed to establish good solid grounds.
In the last picture @Y2KW57 stated “more often than not it is the ground” is 100% on the mark.
When diagnosing trailer lighting systems, here is my order of business.
Bulbs good? Check
Fuses good? Check
Next step.......make sure all circuits are properly grounded On said trailer / make sure said trailer is properly grounded to tow vehicle before going any further.
Good luck
I have tested power at fuse box for fuse 99, trailer running lights…. It has 12v
I have 3.4v (pin3) at the trailer running lights 7 pin connector, but it needs 12v on the number 3pin… brown wire.
So I went to the trailer control module, beside emergency brake pedal. The brown wire is trailer running lights… it reads 3.4v also with lights in on position.
Something is wrong after the fuse box to the trailer control module.
Right now the Suspect is the module itself, but I’m not 100% sure
OP…. Did you find the problem with yours? We may have something in common.
All fuses ok
I cut the brown wire running into the trailer control module, and attached 12v to it from the battery for a test.... trailer lights now work.
So the trailer control module for trailer running light is not working, and probably was like that from the factory.
The truck is out of warranty. I'm thinking of running a tap fuse from the passengers footwell fuse box, and adding a toggle switch to turn the trailer running lights on and off. I have no upfitters.
My trailer is a 16' enclosed with all LED lighting so not much draw I'm guessing? I have adjustable pedals rated for 15amp and will never use them....maybe run off that? or should I find something with higher amp rating?
I have no moonroof, and that's rated at 30amp.... could I just add a fuse tap to that empty slot?
Cost me $12. for the switch and already had a few feet of 14g wire laying around
Works good, no visit to the dealer!
In the manual for the truck fuse box we found a "trailer tow lighting module". The fuse for this was intact and not blown. We went through the trailer set-up on the truck, but could find nothing to turn on or off pertaining to running lights. So after checking everything out, for hours, we decided that something is probably not set correctly in the computer. This is my first Superduty, my last truck is a 99 F150, so I am totally overwhelmed with all the features and capabilities. I only have ~500 miles on my new truck, (picked it up 5 days before the C-19 shutdown), so forscan stuff is like a foreign language to me!
I will search here and on Goggle and YouTube, but put this out here first cause this is where I got all my info to order my truck. So thanks in advance and for services already rendered. Dave
