Bronco II Ford Bronco II
Major Electrical Problem
Old May 29, 2020 | 08:15 PM
topflite10's Avatar
topflite10
Have a 88' BII w/ 2.9 5 speed. Got every conceivable symptom of electrical problem u cud imagine for bout a week before it quit and wouldn't run. Cranks but wont run. Computer grounded from battery, battery to front near radiator, and from battery to frame, and from firewall to engine. COIL has NO SPARK and is getting 12v's on both terminals with key on. Coil is new as well as Ignition module, Ignition switch, Starter Relay, and just put a new Pick up in the Distributor(stator). Has new Battery. Both Fuel Pump and EEC Relays are new. New Plugs, Wires, Dist. Cap, and Rotor. On Compression Stroke on #1 and Rotor @ #1. Bought a new Computer for it 7 years ago and hate ta say it but it's acting jus like it did before that computer went out! Also noticed las cuple days i don't hear my fuel pump kickin' in when i turn the key. AND i tried to pull codes off the "self test" connector and it's like dead...nothing. ALSO...there are 6 different SENSORS supposed to be getting a 5Volt reference signal. ALL of them are getn' 12Volts AND all GROUNDS are 12Volts as well! I've "jiggled" and jerked every damned Harness and wire under the hood and dash and nothing changes...still 12v on everything. Think i've got a major SHORT TO GROUND PROBLEM or BAD COMPUTER! ANY ideas guys? I AM LOST! HELP!
topflite10
Bronco II
Sep 7, 2020 10:06 PM
topflite10
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 11, 2020 06:24 AM
DENVER43
Nov 11, 2011 08:56 PM
