Level it
Old May 28, 2020 | 10:09 AM
kidd joe's Avatar
kidd joe
Level it
I have a 2017 f150 4x4, if I put a 3 inch leveling kit on it could I put 35x12.5x20 Tire’s on it without rubbing or trimming?
Old May 28, 2020 | 10:51 AM
jimmy-six's Avatar
jimmy-six
remember to reset your headlights.Thanks..or you can just be an a-hole to the guy you are following if it matters to you..
Old May 28, 2020 | 11:21 AM
IndyDog's Avatar
IndyDog
Be careful with 3", you're possibly messing with the front end geometry a bit much without a legitimate lift, you should do some research. From my understanding 2.5 is about the limit without replacing the UCA's at a minimum.
Old May 28, 2020 | 11:26 AM
johnday's Avatar
johnday
It might work with a 3" level, some depends on the offset of your wheels, plus, I wouldn't recommend a 3" anyway.
On the 13th gen, you can go 2.5" with no problem. I've done just that on a '17, and now a '20. I've also run 315/70/17 tires on both, with +34 Raptor OEM wheels, zero problem. Those tires measure 34.4" diameter, and 12.50 wide. 315mm divided by 25.4= 12.40 and some change.
You've got a variable there that could make or break the idea.
If you "really" want 3", go ahead and do it, there's a couple guys running around up here that are, and claim no trouble, but geez, that makes for some really bad angles on the UCA, and your CV's.
Old May 28, 2020 | 01:52 PM
kidd joe's Avatar
kidd joe
my tire size is actually 325/60/20 and I can’t see only going up 2:5 inches and it not rub on anything.
Old May 28, 2020 | 03:55 PM
scott91370's Avatar
scott91370
...that makes for some really bad angles on the UCA, and your CV's.
Not to mention the amount of downward travel of the suspension is going to be almost none.
Old May 28, 2020 | 06:16 PM
JKBrad's Avatar
JKBrad
If you want 35s on a 20” wheel, go with a 285/65/20 (34.8”) on the factory wheel an it will fit without any rubbing. 12.50 is usually going to be too wide. Every tire company has lightly different specs though. If you go with an aftermarket wheel, stick with a 5.5” backspace and you wont rub on the crash bars. Most 35/12.50s are 34.5” BTW.
As everyone said above, 3” is too much. That much will wear your ball joint and CV joints quickly. You can easily get 35s to fit with 2.5”.
Old May 29, 2020 | 07:07 AM
johnday's Avatar
johnday
YIKES!! That 325/60/20 is about 35.35" tall, ya, don't think that will work with a 2.5".
Raybo1212
Apr 4, 2020 10:30 AM
jdhudall
2009 - 2014 F150
May 17, 2013 12:19 PM
217Bazan
2009 - 2014 F150
24
Jan 18, 2011 02:04 PM
99sdpstd
Feb 24, 2003 10:18 AM
Wyrm
Jan 15, 2002 09:56 PM
