Dead Cylinder question...
When initially trying to get this new motor started the #5 intake threw the rocker arm. I "thought" that I fixed it and after a few phone calls to Edelbrock regarding proper mapping.... she fired up, I broke her in properly and have been running/driving for at least 30 minutes per week. Well, did a compression test today and #5 was at ZERO!!! I pull the valve cover and realize that I didn't have the dadgum pushrod on the dadgum lifter. I get it aligned "correctly", do a few test runs with the valve cover off and it seems to be fine. I must have nicked a wire or unplugged something on the EFI because she won't stay running.... but she sounds MUCH better and smoother than before....
My question is.... do you think I damaged anything by running on 7 cylinders for that duration of time??
A dead cylinder can mean that the piston was run with no lubricant as the gasoline would wash the cylinder walls and cause premature wear on the rings and or cylinder itself.
Run it on all eight for a few hundred miles and do a compression test.
