Center Cap Issues With Custom Wheels
Old May 26, 2020 | 07:39 AM
wjeffs89's Avatar
wjeffs89
Howdy folks. I recently bought new custom wheels for my ‘94 F-250 and seem to be having a problem getting the center caps to work. Is this a common problem with the hubs sticking out so far and if so what are the solutions? Thanks
Old May 26, 2020 | 10:01 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Common problem? I would guess not. The topic doesn’t pop up very often.
I assume you are talking about rear hub? Was this wheel and cap listed as fitting this vehicle from the manufacturer? Is there a deeper cap available to exchange?
Old May 26, 2020 | 11:05 AM
GNR22's Avatar
GNR22
I'm sure we all know what you're talking about. Unless you can get different caps for the wheels you bought, you're kind of SOL. I know American Racing has deep enough caps, but I don't know about anyone else.
Old May 26, 2020 | 01:39 PM
torq'ta 5 8's Avatar
torq'ta 5 8
2wd, 4wd, front, rear, both, dont fit?
Old May 26, 2020 | 06:38 PM
Diesel_Brad's Avatar
Diesel_Brad
Common problem? I guess for non ford guys. But for anyone that has ever put aftermarket wheels on aFord before we know you need deep center caps
Old May 26, 2020 | 07:54 PM
mrollings53's Avatar
mrollings53
Post the make and model of the wheels you're installing. There might not be a specific cap for 8x6.5" wheels on these trucks, but the caps for later 8x170mm wheels might fit.
You're not the first with this issue:
https://www.ford-trucks.com/forums/1...l#post17544548
Old May 26, 2020 | 09:48 PM
wjeffs89's Avatar
wjeffs89
4WD, front and back don’t fit
Old May 26, 2020 | 09:49 PM
wjeffs89's Avatar
wjeffs89
Wheels are ION 141. It came with the same caps for front and back
Old May 26, 2020 | 09:52 PM
wjeffs89's Avatar
wjeffs89
Old May 27, 2020 | 01:09 AM
My4Fordtrucks
Well that’s obviously not going to work. You can’t have an enclosed center cap on the front
Old May 27, 2020 | 06:05 AM
wjeffs89's Avatar
wjeffs89
Obviously. Front is manageable by popping out the center of the cap and dremel out the hole a little more to fit. I didn’t clarify the back is the bigger issue. Thanks everybody for your help. It is looking like unless the manufacturer has a deeper cap I’m SOL and need to look for other options
Old May 27, 2020 | 09:20 AM
My4Fordtrucks
Ah. I did not know the cap is two pieces. The rear center caps for my Alcoas are one stamped piece.
Old May 28, 2020 | 06:03 PM
mrollings53
https://www.ionalloy.com/contact
Ask the manufacturer. You should also go back to where ever you bought the rims. Ion only sells to dealers, so you'll end up back there anyways.
Old May 29, 2020 | 10:16 AM
ZSK's Avatar
ZSK
I like the look without hub caps especially in the front. Paint the hubs with a fresh coat of black, tape off the chrome cap for the lockout.
Old May 29, 2020 | 01:37 PM
sandymane's Avatar
sandymane
I had the same issue with my wheels. The back center piece would not work because of the hub.. The center piece is held on by three allen bolts that you can see in the picture. What I did was bought some hollow pipe from HD and some longer black allen bolts. I cut the pipe to the correct length and painted the pipe black and the very small space between the center piece and the hub was painted black. I don't think you can tell even by this picture it has been modified to fit.
