Center Cap Issues With Custom Wheels
Old May 29, 2020 | 10:01 PM
westcoasting's Avatar
westcoasting
Originally Posted by sandymane
I had the same issue with my wheels. The back center piece would not work because of the hub.. The center piece is held on by three allen bolts that you can see in the picture. What I did was bought some hollow pipe from HD and some longer black allen bolts. I cut the pipe to the correct length and painted the pipe black and the very small space between the center piece and the hub was painted black. I don't think you can tell even by this picture it has been modified to fit.
what pipe did you use? Looks great!!
Old May 29, 2020 | 10:22 PM
sandymane's Avatar
sandymane
It's in a HD section where they sell this in different sizes and also flat bars in different thicknesses and lengths. The tag says Round Pipe on it. Your screw or whatever you get that secures the center cap will need to fit through the hole in the tube and the tube should be cut just long enough to make the center piece clear the hub. Sandy
FLARESIDEDADDY94
Florida Chapter
Jun 12, 2016 02:30 PM
FFBlink
Feb 15, 2016 12:30 PM
powerstroke8806
Oct 5, 2015 09:15 PM
justinf-250
Jan 31, 2011 07:39 PM
