Bumper width
Old May 25, 2020 | 08:05 AM
EBEAR's Avatar
EBEAR
Bumper width
I am keeping an eye out for some " different " bumpers and my truck is disassembled and I don't have original bumpers . Can someone measure the front width with the consideration that I may find something that wraps to some extent around the front fenders . The rear is less crutial but my box is complete so I can check on that . Thanks in advance .
Old May 25, 2020 | 08:26 AM
avf100's Avatar
avf100
I measured across the top of the bumper.
70 3/4"
Old May 25, 2020 | 08:48 AM
EBEAR's Avatar
EBEAR
Thanks avf100 . Would that be wide enough to allow for a bumper that wrapped around and some what back over the the front of the fenders ?
Old May 25, 2020 | 09:22 AM
avf100's Avatar
avf100
I'm guessing you might need it to be a little wider.
Old May 25, 2020 | 11:45 AM
EBEAR's Avatar
EBEAR
That's a perfect shot avf100 . Your measurement across the top would be pretty close to the inside width of any wrap around I may find . Thank's
Old May 25, 2020 | 08:40 PM
56panelford's Avatar
56panelford
You could look for a bumper off a bigger truck of the same years , they already wrap around..
Old May 25, 2020 | 10:12 PM
CharlieLed's Avatar
CharlieLed
Then there is always the ultimate "darksider" solution...
Old May 25, 2020 | 10:53 PM
EBEAR's Avatar
EBEAR
Yes much more along those lines charlieled . I will be eliminating as many square edges as possible . I find the sharp square edges such as the bumpers , the front top of the box , the box vertical supports , the running board edges and other places kind of out of place on a predominantly rounded smooth body . How many I change will depend on my patience , time and the complexity of doing it . Do you have any info on that pic you posted ?
Old May 26, 2020 | 06:12 AM
avf100's Avatar
avf100
Looks like it could be a 55-59 Chevy truck front bumper.
Old May 26, 2020 | 06:16 AM
CharlieLed's Avatar
CharlieLed
That is the bumper on my 56 F100, it started out life on a 56 Chevy truck. I believe that all tri-five truck bumpers are the same. I started out by fabricating custom bumper mounting brackets and welding mounting studs in the bumper bar. This cleaned up the mounting part of the job. Next I trimmed the edges of the bumper bar to fit the contour of the fenders/valence...this is a little more art than science but if you don't take off too much material at any given time you can massage it into place nicely.
Old May 26, 2020 | 08:11 AM
EBEAR's Avatar
EBEAR
I was originally hoping to find a factory bumper that would work but after doing a little checking it seems that getting something chromed isn't much difference in price so that definitely opens up the options . Do you have any more pics ?
1950FordF1
Feb 3, 2015 08:02 AM
Biggziff
6.7L Power Stroke Diesel
Feb 18, 2011 09:31 AM
78 explorer
Sep 3, 2008 07:12 AM
rhmitchel
May 1, 2003 01:48 PM
